11-16-2020, 03:21 PM | #1 |
Rep 138
JB+ Review
Ok so I literally just received my JB+ and got it installed. Have it set to the default setting which is a little more than half way.
Didn't feel any jerkiness at all. Transmission is still shifting quick but....... I feel like it changed the cars character (not so much of a good thing). Yes the top end pulls harder but it's not as snappy at low RPM's as it was before (on Sport Plus). Have any you felt the same way ? |
11-16-2020, 03:24 PM | #2 |
Rep 138
Have this paired with a Catted downpipe*
M340i Pride209.00 |
11-16-2020, 04:10 PM | #3 |
めらみぽっぷ fan
376
Rep 345
Same story on my 330. You basically laid it out: more turbo lag in exchange for pulling harder higher up. Maybe someone can give a proper technical explanation, but I would assume it's cutting fueling due to thinking boost is low, for efficiency. JB+ tricks it into thinking boost is low, so it waits for boost to build to 'normal' levels.
Personally, I don't mind as I'm not in a rush to get to ~45mph or lower. Still responsive enough in comfort, but pulls harder when I actually get a chance to put it into Sport+ and give it more than 50% throttle.
M340i Pride209.00 |
11-16-2020, 04:18 PM | #4 |
Rep 138
Yeah I'm not sure what the technical answer would be but I'm sure it has to do something with that.
I just increased the boost so we'll see how that goes |
M340i Pride209.00 |
11-16-2020, 06:06 PM | #5 |
Rep 949
The JB+ makes more power and more torque across the power band. Behind the wheel will feel the top end pull a little more now making the torque gain not as noticeable but at no point do you make less torque than factory.
M340i Pride209.00 |
11-16-2020, 06:50 PM | #6 |
Rep 138
Just cranked up the boost to about 80%
And definitely feels better |
M340i Pride209.00 |
11-17-2020, 07:38 AM | #7 |
Joint Chiefs of Staff
24191
Rep 190,805
the Jb+ adds the same amount of boost across the RPM, it does not add any turbo lag
M340i Pride209.00 Merami fan376.00 |
11-17-2020, 08:38 AM | #8 |
Rep 138
Mike you're right . I guess in the mild setting I was expecting more . Nevertheless I'm happy with the product.
Btw thank you xtreme powerhouse and team! |
M340i Pride209.00 |
11-17-2020, 11:43 AM | #9 | |
Rep 1,712
I just lowered it to 4'0 clock. I want to say, it feels more even. I'll post a quick update. |
11-17-2020, 12:17 PM | #10 |
Rep 138
Could you post where your dial is set at (picture preferred) so I can give it a shot
M340i Pride209.00 |
11-17-2020, 12:48 PM | #11 |
Rep 1,712
If I get a chance, ill post the pic in my thread. But I was pretty careful to be right on 4'o clock. I used a fine flat head to gently adjust. So far, its been good. Can't wait to drive home after work today lol
11-17-2020, 02:51 PM | #13 |
Rep 1,712
In your opinion, is here a setting that is best for you? Or do you just turn it up all the way? Curious how other users are feeling about it.
rrfitness2076.50 |
11-17-2020, 02:53 PM | #14 |
Rep 1,712
That's the 2'o clock. The default setting was on 3'o clock. In a simple way, that is probably a bit less than 2psi over stock, since the 5'o clock max boost was said to be 4.5 psi over stock. So 1.75?
Just my best guesstimate. |
11-17-2020, 07:12 PM | #15 |
Rep 138
I'm still trying to find the right setting
It's more of a trial and error for me. I removed it, felt how it was factory again and now I just put it back lol. So we'll see. |
M340i Pride209.00 |
11-17-2020, 09:02 PM | #16 |
Rep 1,712
11-17-2020, 09:08 PM | #17 |
Rep 138
I was honestly impressed.
Felt a little kick after 3k but pulled harder throughout the entire power band. |
M340i Pride209.00 |
11-17-2020, 11:23 PM | #18 |
Rep 1,712
I see! Makes me looking forward to it. May be more isn't better with jb+. Perhaps lighter boost works better with the car's engine tuning and the transmission.
11-18-2020, 07:38 AM | #19 | |
24191
Rep 190,805
Barring any mechanical issue (that can be causing misfires with higher boost) or traction control problems, this car should be able to handle all the boost it can get from the JB+
rrfitness2076.50 M340i Pride209.00 |
11-18-2020, 04:09 PM | #20 | |
Rep 1,712
