07-23-2019, 01:42 PM | #1 |
Rep 53
2020 M340i - Rough Transmission Shifting at Slow Speeds (under 25 mph)?
I have about 500 miles on my new 2020 M340i. It's wonderful - possibly the most fun car I've ever owned. However, when driving "casually" (not sporting it around with fast accelerating), my car seems to shift very quickly from 1st thru 4th of 5th gear when driving in Comfort Mode. It creates what somewhat feels like the old days when your car would "miss" or skip (or surge back and forth). I don't recall this occurring the first 300 or so miles, but then again, those frist two weeks I was driving fairly aggressively having too much fun. Now, I'm settled back to my more normal conservative driving habits until someone new is in the car that I need to impress! Anyone else have similar experience at slow acceleration and slow speeds under, say, 20-30mph. Once above this speed all is smooth. I guess the car is built to mainly go fast - which does impressively - than too slowly?
07-23-2019, 02:12 PM | #2 |
Rep 271
Shifts shouldn't be perceptible in comfort mode when applying light (I'd say up to a third) throttle. When I have music on and I'm accelerating lightly in comfort mode I can't even perceive the shifts unless I'm looking at the tachometer.
07-23-2019, 02:49 PM | #3 |
Rep 34
Is it only when you first start your car? Mine does this after just starting it, then after about a minute of being on it stops and guess back to normal. Figure is a safety feature for temperature or fluids or something.
07-23-2019, 03:49 PM | #4 |
Rep 53
Thanks...I would have expected what you are saying. I'm going to give it a few hundred miles and see if it settles out. I may have "learned" I'm an aggressive driver and now needs to learn that was temporary. My work around right now is to switch directly into Sport mode now on the neighborhood streets where you only go about 25-35 mph... this not only eliminates the symptom I'm having but takes it turns off the on/off start engine button... I'm pushing one of the two buttons regardless...so will go with Sport, for now. Once I'm on to over 25mph streets, will switch back to Comfort most of the time. I'm hoping this isn't a long term procedure but not horrible if it is.
golferboy231278.50 |
07-23-2019, 03:53 PM | #5 |
Rep 53
Mine seems only be perceptible for the couple of minutes I'm in the neighborhood. Once out of the neighborhood, I'm accelerating enough in Comfort mode to eliminate the symptom. It's the very light accelerating where it seems to go from 1st thru about 4th or 5th gear very quickly getting to just 25mph. I'm surprised it even goes to this high a gear at this speed, but the rpm's allow it for the best mileage I guess. Seems 3rd or 4th would have been the max gearing, but they didn't ask me. Btw - I did drive it with the foreman today and, of course, we could not feel any surging/skipping on the 15 minute test drive no matter how hard I tried to duplicate it for him... Typical - right? I'm not losing sleep over this. The fun far outweighs any of this minor nuisance.
07-23-2019, 05:24 PM | #6 |
Rep 381
Bro. Owners manual!! How hard were you driving?? You gotta break the vehicle in lightly, might have been hard on the tranny while it was not yet set in, ??
07-23-2019, 05:59 PM | #7 | |
Rep 53
I'll never use "launch control" I've read will reduce a car's life even on a well broken in. As far as revs and rpms, I've not come close to 100 mph though rpm's probably have exceeded the recommendation - but that was likely even on the test drive...that's even worse! My use of aggressive I don't believe is anything close to real enthusiasts - though, in retrospect, I probably should have been a little more respectful. Thanks for your post. |
07-23-2019, 06:01 PM | #8 | ||
Rep 381
07-23-2019, 06:43 PM | #10 |
Rep 53
Thanks! The first minute or two is the worst, but still noticeable if I'm looking/thinking about it. But, usually after a couple of minutes I'm on roads where I can accelerate a little faster which eliminates/mask the issue. Not hard acceleration, but like you do if your target is 35-40 mph rather than 20-25 mph around the neighborhood.
07-23-2019, 06:47 PM | #11 | |
Rep 53
07-24-2019, 12:12 PM | #12 |
Rep 334
i know this might sound tedious, but if you have a recurring problem that you cannot replicate to a tech, maybe go get yourself a small journal at the dollar store so you can record the behavior each time it occurs... noting the date, time, road conditions, and ambient temperature. a pattern may surface that you did not see before.
07-24-2019, 01:24 PM | #13 | |
Rep 53
07-24-2019, 02:31 PM | #14 | |
Rep 15,858
Your 'sport to comfort' changes do seem to be the opposite to how we'd expect smooth operation. Comfort at low speeds should be the best for seamless changing, sport a little more feel through the gears. Can't see how any AT needs a sport program, to give a smoother shift pattern at low speeds. I'd definitely experiment with how you drive. Note your throttle inputs, how you brake, etc., see how different inputs affect the smoothness of the gearbox. See if the gearbox adaptations (as you drive) are involved. |
07-24-2019, 04:45 PM | #15 | |
Rep 53
07-24-2019, 05:26 PM | #16 | |
Rep 15,858
The other thing that often causes confusion, is the actual gearbox adaptation values, values that can be reset, (typically after gearbox repairs), which require a relearn procedure. But that is a completely different subject and function than driver influenced adaptions. Gearbox values are automatically adapting/changing, allowing for clutch wear, clutch pressure & fill times, etc. |
08-15-2022, 05:57 PM | #17 | |
Rep 32
08-16-2022, 05:24 PM | #18 | |
Rep 701
In sport, especially sport+ and if you leave the car in auto, more so in Sport Auto, the car would keep in lower gear as long as they could, in case if you need WOT at any moment. The car in those mode does not like be driven "normally". Using paddle shifter would help tho. You shouldnt feel anything like if you leave everything in comfort without Sport Auto (shifter to the left). Individual Sport with Transmission in comfort is the best all around option. |
08-24-2022, 11:09 AM | #19 | |
Rep 32
08-24-2022, 01:19 PM | #20 | |
Rep 701
I have driven plenty of ZF8 with different BMW models, i have yet experienced anything like that except when in sport+ in the city that the car really hates to upshift during normal acceleration. |
09-28-2022, 04:12 PM | #21 | |
Rep 9
