06-20-2021, 01:58 PM | #111 | |
Rep 6,856
Drives: '18 M550i|'21 X5|'03 540i
Garage List 2013 VW Tiguan [0.00]
2015 Infiniti QX60 [0.00] 2021 BMW X5 [0.00] 2003 BMW 540i [0.00] 2018 BMW M550 [10.00] |
2018 M550ix|Carbon Black|Dinan Modifications|2003 540i|Jet Black|M-Sport|2021 X5 Mineral White
Prior BMW's: 1987 325e|1993 740i|1998 740il|2001 530i|2002 745li|2007 750li|2006 750li|2001 530i|2012 535xi| |
06-20-2021, 02:11 PM | #112 |
Rep 82
How can this work "TCM_MSA_Memory" My 11.20 330d does not have the physical Button for MSA on off anymore, like my old F30, its allways off.
If you set another coding like MSA complete off, i ll get an errorcode in ista from MSA, it works, but don tlike to have the error in the car |
06-24-2021, 04:06 PM | #113 | ||
Rep 15
06-25-2021, 08:33 AM | #114 | |
Rep 207
Hi,
Can i check with you, what is the coding to turn off MSA? Quote:
06-30-2021, 05:15 PM | #115 |
Rep 3
how can I code signal lights always open mode same as picture (with bimmercode)? for headlights rear stop lights and mirror signal lights.
sorry, I don't know the name of this option |
07-05-2021, 10:10 PM | #116 |
Rep 167
Does anyone know how to change brightness of low beams?? Mine were accidentally coded to be really bright I need it back to factory setting. Please help me out!
07-06-2021, 02:57 AM | #117 |
Rep 1,810
From everything I've read on this forum it's not possible to make the lights any brighter. This is the first time I've heard. Perhaps the voltage parameters were changed? Worst case scenario is to revert back to the original FA and code the ECU.
07-22-2021, 06:45 AM | #119 |
Rep 39
Drives: 2021 BMW X3, 2019 Shelby GT350
About to jump in to this, I had previously coded my Ford's in a similar manner. Can we code the fog lights to always come on with low beams (Every time the lights go on, there is no "memory" of the fog lights being on.
its silly, but most of this is just for fun, right? |
07-22-2021, 08:57 PM | #120 |
Rep 29
Bought Bimmercode and coded for the first time today...sport + and the 5 click turn signal. WOW sport + mode made a huge difference.
Probably dumb question...I see some people changing their BMW chime to the Rolls Royce chime. Is the chime from older BMWs still in the system anywhere? The new one is nice but I really miss the e90 chime. |
07-27-2021, 03:35 AM | #121 |
Rep 568
Bimmercode for iOS downloaded an update for me last night... I can't seem to find release note anywhere.
Anyone know what's new?? |
07-27-2021, 03:28 PM | #122 |
Rep 216
Can you adjust the volume for the turn signal and warning chimes using Bimmercode on a G05? I've already set them at the minimum via the settings/sound menu but they are still loud since I installed an aftermarket amplifier.
08-02-2021, 03:24 PM | #123 | |
Rep 23
I have the stock speakers. Because of that I don’t have the EQ settings. My question is if I enable the EQ settings, will they actually show up and work? If so, that’s amazing! |
08-02-2021, 03:52 PM | #124 |
1949
Rep 3,520
The EQ will show up but nothing will happen with the base HiFi system. You need the HK system for it to work.
08-03-2021, 10:42 AM | #125 |
Rep 29
Any way to enable the turn signals being display in the HUD? I saw a video where this was done on a different model BMW.
https://www.youtube.com/watch?v=hTWRxueFqtc |
08-03-2021, 10:58 PM | #126 | |
Rep 156
08-06-2021, 08:02 PM | #127 | |
Rep 4
08-06-2021, 08:04 PM | #128 |
Rep 4
i have bimmercode cheap, can i use expert to code lighting system instead of esys? central locking is down and headlights/taillights are on unless i unplug FEM
08-23-2021, 07:43 AM | #129 | |
Rep 19
Thanks! Sam |
08-24-2021, 06:16 AM | #130 |
Rep 1,480
Drives: 2020 M340Xi (G20)
samcrooks182,
To use Active Lane Change Assistant, not only do you need to code your car as per cheatsheet, but your car needs to have Active Cruise Control (believe it's part of Driving Assistant Pro, S5AUA). Having said that, it is a great feature on highways (Motorways), particularly on trips. With ACC engaged, to change lanes, you pull your turn signal stalk in the direction you want to go almost to the midpoint of turn stalk, just short of stalk lock/click point. An arrow shows up in center of instrument cluster (and in HUD, if equipped); the car will then change lanes automatically when it's safe. As I said, I find it particularly useful on highways Hope that helps!
Al
08-24-2021, 03:05 PM | #131 | |
Rep 2,700
I only have bimmercode, do you guys know someone who could remote code this on my car ?
Fun/HPDE: 2023 M3 6MT Individual Malachite
Past:2023 M4 CSL, 2022 M4C Vert, 2020 M340i, 2018 M2, 2015 M235i, 2008 135i 550whp Daily: 2023 X5 45e Daily/Family: 2021 Atlas Cross Sport 3.6 |
08-26-2021, 01:01 PM | #132 | |
Rep 95
Wait you can code wireless charging now?
