03-30-2020, 10:37 AM | #1 |
Rep 1,687
Ventilation programming
While I appreciate this can be done via Connected, has anyone discovered how to programme the ventilation to come on at a set time iemprogramming in the car.
The reason I ask is that in my f34 I could,programme two separate times which I found really useful- Connected only allows one. |
04-04-2020, 02:22 PM | #2 |
Rep 43
Yep, this can be done via iDrive
1. "My Vehicle" 2. "Vehicle settings" 3. If applicable, "Climate comfort" 4. "Auxiliary ventilation" or "Auxiliary heating/ ventilation" 5. Select the required departure time. 6. Set the departure time. 7. Select the day of the week if necessary. |
Seaford1147.50 |
04-04-2020, 10:35 PM | #3 | ||
Rep 190
Drives: M4 Comp Pack San Marino Blue
One would think reading the menu on the idrive it was possible to pre heat the car. Sadly the software option for us UK owners is miss leading. It was the same on my 640d & my 635d & current M4. I spoke to my dealer & extra hardware is needed. It's not an option that can be fitted to a RH drive UK car. You can however circulate air however not air that has been cooled by the aircon system or heated. More info here I'm guessing that it's not the engine which heats the system when you select it but a separate heater There's a similar post here https://x3.xbimmers.com/forums/showthread.php?t=1348214 bit more info here https://www.pistonheads.com/gassing/...6&t=634121 I think your dealer would be able to advise. |
04-05-2020, 05:07 AM | #4 | |
Rep 1,687
I am going to,digress now........did you know the sunroof closes automatically when it rains when the ignition is off. A pretty cool,feature....but not sure I am brave enough to test it!! |
04-06-2020, 08:16 AM | #6 |
Rep 2,699
Drives: 23 X5MC
Surprising how many people don't read the owners manual
