04-01-2024, 01:41 PM | #1 |
Rep 37
Early & uneven tire wear (i4 M50)
Hi,
I have a '23 i4 M50 with around 7k miles. Have had it for over a year mostly for local commute. I happened to be at the local dealer for another issue and they told me there is heavy tire wear on the rear tires, they are almost gone. Would be 750$ to replace just the rear tires. My question is the following: why is there uneven wear on the i4 M50? The battery weight is distributed across the front and back right? and it is a dual-motor i.e., 4 wheel drive? Shouldn't the wear be even between front and back? Also have others had to change their tires after 7K miles? Seems too early even for a heavy electric car. Hankook is the brand of tires I got, if that matters. -Ram |
04-01-2024, 01:45 PM | #2 |
Rep 1,177
When I connected Bimmerflow to my M50, one thing that was noticeable is that power only went to the front wheels when you were accelerating fairly hard. General cruising seemed to be rear-wheel drive.
04-02-2024, 08:28 AM | #3 |
Rep 403
Is dealer suggesting an alignment issue? While the car is heavy I would think 15,000 miles would be a reasonable expectation, even if your right foot is a bit aggressive (from time to time)
04-02-2024, 11:08 AM | #4 |
Rep 3,274
Granted, my M50 is on order, but I've been on the this and the i4 talk forum for a little while now.
From what I understand (and from my own experience with hankook tires on other cars), out of all the OEM tire options on the M50, they wear out the fastest, by far. The sport hankooks I've had on other cars are great, but they have worn fast for me... however the quick wear borders on ridiculous for the M50. There is likely more tire wear in the rear because even though the car has power to all wheels, the delivery is very rear biased. A lot of the time the car is full RWD unless the front is needed for launching, cornering, etc. Maybe try swapping out the tires completely for a full set of another brand of OEM BMW star tires. The pirellis and michelins will likely wear much better.
2022 X4 M40i - 2008 135i - 2015 F700GS On Order - 2024 i4 M50 Scruffy's gonna die the way he lived... Mmhm. |
04-02-2024, 10:54 PM | #6 |
Rep 1,424
Drives: '23 i4 M50, '15 M3, '18 911
Yeah we have major tire wear in the inside of the rear tires on our M50. I didn’t notice until the rears were corded on the inside. Got about 13K miles before the rears had to be replaced. The fronts are still going strong at 18K. I estimate I’ll have to replace the rears twice for every change of the fronts.
04-03-2024, 09:45 PM | #7 |
Rep 117
Had the Hankooks from factory on my M50 and had to replace them due to the rears being worn at 6k.
04-04-2024, 01:39 AM | #9 |
BMW Elite Master Tech | HV Gen 5 | HV Specialist
3528
Rep 4,216
Please specify what kind of wear you have. Talking about having uneven wear but not stating what is uneven is leaving out information of tire measurements. It is very common for any BMW to have heavy rear tire wear before the front. Completely normal for an i4 M50 especially if you like to accelerate a lot. Tires don’t last 30k miles anymore especially for any of these BEVs.
04-04-2024, 12:57 PM | #10 | |
Rep 37
04-04-2024, 03:07 PM | #11 |
3528
Rep 4,216
All too common with BMW EVs now. Completely normal. Customers don’t realize tires will be replaced much more with EVs.
04-13-2024, 09:45 AM | #13 |
Rep 1,328
04-13-2024, 04:07 PM | #14 |
813
Rep 3,978
I got 8,000 miles on the original Pirelli Pzero summer tires. Switched to the Goodyear Eagle Sport All Season Tires. OEM German made tires with a 500 tread wear rating. Good in damp conditions and good enough in the dry. I think I will be on track to get 12000 miles on them, which is about 50% more than I got on the Pzeros.
2011 Alpine 335d M-Sport 12.34 @ 110.48mph
2019 i3s Terra, 2008 Black 335i Sedan. 11.11@ 129.47 mph 2008 Monaco Blue JB3 2.0 335i Coupe. 11.33 @ 132.77 mph, 60-130mph: 6.95 seconds 2023 i4 M50 11.48 @ 121.56mph, 3.43 0-60 (dragy) |
