03-29-2022, 08:12 PM | #1 |
Rep 80
Widest Tire for 791M Wheel?
22M340i Xdrive, I dont have a staggered setup. They are 225/40R19 Run Flats all around.
What is the widest tire I can go with? I want to change to non-run flats when I install my lowering springs. Any recommendations on summer tire? |
03-29-2022, 09:16 PM | #3 |
Rep 620
Drives: Little of this, little of that
Before the thread gets populated with "i don't have that but" posts:
I have the same wheels. Same RFTs on all 4 corners. Dealership told me they would not go over 245 on those rims. You will notice a big difference just going to a good summer traditional tire. I do not think the difference will be as dramatic between the 225 and 245 square setup.
"It's not how fast you go, it's how you go fast"
00dyb5876.50 |
03-30-2022, 06:20 AM | #4 | |
Rep 80
I'm getting stuck on the differences after the width and height of the tire. For example: MICHELIN PILOT SPORT 4 S - 245/40ZR19 94Y TPC ZP BSW vs MICHELIN PILOT SPORT 4 S - 245/40ZR19/XL (98Y) XL BSW Would either of these work or is one recommended over the other? EDIT:
EDIT 2: So I should go with "MICHELIN PILOT SPORT 4 S - 245/40ZR19/[B]XL (98Y) XL BSW"? Not looking for run flats. Last edited by 00dyb58; 03-30-2022 at 06:38 AM.. |
04-11-2022, 11:33 AM | #7 |
Rep 80
Sorry for bumping old thread, but I'm going to pull the trigger on "MICHELIN PILOT SPORT 4 S - 245/40ZR19/[B]XL (98Y) XL BSW" for my 8.0 wheel.
Anyone know for sure if I will have an issue? |
04-11-2022, 01:12 PM | #8 |
Rep 4,210
the technical data for this tire states wheel range 8-9.5"
i have never personally mounted 245mm tires on 8" rims (8x 25.4 = 203mm) so i can't say how it feels but it's within spec certainly cheaper than buying 4 new wheels |
04-11-2022, 01:24 PM | #9 |
Rep 80
04-11-2022, 01:31 PM | #10 |
Rep 4,210
umm ...
you have x drive all 4 tires must have the same circumference are all 4 wheels 19x8"? ie will you fit the 245 40 19 in all 4 corners? |
04-11-2022, 01:35 PM | #11 |
Rep 80
04-11-2022, 01:36 PM | #12 | |
Rep 4,210
i can tell you that most likely you'll have both better grip and better comfort! PS when i wore out those 225s i mounted 245 on the 8.5, same tire brand (PS4) and i now have infinitely better grip and much better comfort ... Last edited by G30M; 04-11-2022 at 07:10 PM.. |
00dyb5876.50 |
04-12-2022, 05:28 PM | #13 |
Rep 80
For the future google searchers, The 245/40ZR19 Pilot 4S tires fit well on the 791M Wheel
View post on imgur.com |
murderedg2089.00 |
04-17-2022, 11:51 PM | #14 | |
Rep 104
Also did you ever toss some spacers on those bad boys? some 15mm would look noice! Last edited by RawDog; 04-17-2022 at 11:58 PM.. |
00dyb5876.50 |
04-18-2022, 06:21 AM | #15 | |
Rep 80
I think I had the worse possible combination
With H&R springs & 4x 245x4019 non run flats the drive is much, much better. I never rode in a G20 with Adaptive M Suspension, but I’m happy with it now. The car doesn’t roll as much either now taking a hard turn. I have 12.5mm spacers coming this week. I'll post some before and after. I'll go with 15mm if 12.5 isn't enough. Couple things I did not expect with the new setup. I'm sure these are the tires, and not the lower ride height.
04-18-2022, 07:53 AM | #16 | |
Rep 104
How was the ride without springs? I do not plan on lowering currently, dont want to be a snow plow in winter. |
04-24-2022, 06:56 AM | #17 | ||
Rep 40
04-24-2022, 06:18 PM | #19 | |
Rep 80
Pretty sure 8.5 is only on the staggered setup from stock. I read if all are 225 you have a 8.0 wheel and 245 is the widest you can go. |
04-24-2022, 06:24 PM | #20 | ||
Rep 40
04-24-2022, 11:59 PM | #21 |
Rep 185
330i m sport that had 225 run flats, went with:
-245/40/19 hankook Ventus s1 evo3 -15mm spacers all around -Dinan springs Wish I went lower there's clearance, car handles and looks the way it should have from factory. |
00dyb5876.50 |
04-25-2022, 12:15 AM | #22 | |
Rep 4,210
it now looks the part and will drive like it really should. can't believe they come in 225s square. madness. your car looks stunning. |
00dyb5876.50 |
