12-31-2020, 10:52 PM | #156 |
Rep 751
Mine works on any multi-lane road IIRC
01-01-2021, 07:01 AM | #157 | |
Rep 464
SAS3--> C_NHA_Spurwechsel_Strassentyp--> Nr001_Alle_Strassen Larry
2020 Black Sapphire M340iX
2014 Estoril Blue 435iX - sold |
01-01-2021, 08:47 AM | #158 |
Rep 1,480
Drives: 2020 M340Xi (G20)
Mine works on not only highways, but also on regular multi-level roads-- no problem
Al
01-01-2021, 10:35 AM | #159 | |
Rep 1,587
01-01-2021, 10:18 PM | #160 |
Rep 46
Drives: 2020 G20 330i
Hi folks
Just finished coding via bimmercode, to enable the dash display. Works just fine, even have the option turned on for 'lane change assist' in the settings now, but obviously it doesn't work because of the SAS module being uncoded to allow it Again I used bimmercode in expert mode to enable all the dash functions, and now my question; I also have the coding cable and Esys software , and when I tried to do that route for coding discovered because I don't have the 3.0 launcher (my understanding is the author has stopped responding to people trying to buy the software) , so all I get when I load the existing 'free' launcher is a load of nonsense I can't understand From my reading the 'launcher' is what makes the config of the car legible by normal people so they can code it properly. Do anyone have a way to find certain coding ; specifically to make this change SAS2 > CAFD_42C1 > C_SWA_VORHANDEN Default: Nr000_nicht_vorhanden Change to: NR001_VORHANDEN Without the 3.0 launcher (basically reading it verbatim from the car) Cheers |
01-02-2021, 04:15 AM | #161 | |
Rep 1,587
01-02-2021, 04:17 AM | #162 | |
Rep 1,587
Seems a bit random as to which work and which don't, but all motorways work. Dual-carriageways are hit and miss. Some auto lane change, some disengage the Assisted Driving. |
01-02-2021, 04:18 AM | #163 |
Rep 46
01-02-2021, 04:45 AM | #164 | |
Rep 1,587
Go for standard 32/64-bit licence. Expert isn't needed unless you plan on doing coding discovery. Dongle version allows it work in a VM and transfer to another PC, but is often out of stock and can take time for postal delivery. Non-dongle is much cheaper but is tied to the physical PC its installed on. |
01-02-2021, 05:01 AM | #165 | |
Rep 46
non dongle is fine, as i have the enet cable and a dedicated laptop anyways cheers ! |
01-21-2021, 07:44 AM | #166 |
Rep 10
Hello,
I just recently received my G20 which has software 2020.11 installed. I tried to code lane assistant but it doesn't work with the message: CAFD_00007083_023_060_113 Fehler: File for "cafd_00007083-023_060_113" not found! [C012] As far as I understood the psdzdata i used (PSdZData Lite v4.26.22) is outdated. Do you know where can i get the latest data please? Update: Found new data. it works now! Last edited by Turisto; 01-21-2021 at 08:41 AM.. |
03-17-2021, 03:59 PM | #167 | |
Rep 13
03-17-2021, 05:45 PM | #168 | ||
Rep 1,587
03-17-2021, 05:46 PM | #169 | |
Rep 1,179
03-23-2021, 08:49 AM | #171 |
Rep 5
So I'm not sure where I went wrong (screencap included) but when I tried to open up DKOMBI4 for coding this is what showed up instead of what was expected. Any help is appreciated!
03-23-2021, 09:11 AM | #172 | |
Rep 1,179
I believe you have the latest psdzdata. I used Esys 3.32.1 with an updated version of EsysX which I downloaded this month. |
03-23-2021, 09:21 AM | #174 | |
Rep 1,587
There is sometimes mappings for older i-step and older psdzdata but based on your screenshot, 2.8.2 is missing the mappings. You need to buy esysx |
03-23-2021, 09:25 AM | #176 |
Rep 5
Damn, was trying to avoid paying anything more but thanks for the help!
