03-27-2023, 07:04 PM | #23 |
Rep 562
HC does also offer custom tunes...so any conflict of interest exists between both platforms and the people who do their tunes (although from use of both - neither one is making a bad OTS tune to try to get you to use their custom services)
I will note that when I was using BM3, the support on the tunes was absolutely incredible, and led to the development of some new features. I worked directly with BM3 to develop and test the throttle mapping sliders.
2019 X3 M40i | TU Pump | AA DP | VTT GC | xHP Stage 2 | Dorch ECA | MHD Odin FF | Carbon Black | Adaptive Suspension | M-Sport Rear Diff | 20" staggered
SOLD! 2015 X1 35i | Alpina Trans Tune | Dinan Stage 2 | Bilstein B6 |
03-27-2023, 07:34 PM | #24 | |
Rep 1,468
Ive also submitted logs in the past and the advice they have given me was nonsense. I ended up fixing issues on my own, contrary to what they said was wrong. I think the real answer for the M340 is ECUtek which I may switch to.
2014 EBII 435ix - Stage 2+ Dragy: 0-60 3.61; 60-130 10.18
2020 MG M340ix - Dragy: 0-60 3.48 2018 LBB X4M40i - Stock Dragy: 0-60 4.85 |
03-27-2023, 07:53 PM | #25 | |
Rep 562
https://ecutek.atlassian.net/wiki/sp...8+Tuning+Guide I learned a lot from reading that.
G20Debug1.50 |
03-27-2023, 09:57 PM | #26 | |
Rep 564
Don't mean to light you up and position you as the expert - I'm just trying to understand - please anyone else jump in here for clarity's sake thank you |
03-27-2023, 10:04 PM | #27 | |
Rep 1,468
My logic is that if BM3 and mhd OTS maps are not good and I need a custom tune, why not just get the platform that allows for the best result. I am still trying to figure out the best route for myself. What I can tell you is that Bm3 93 tunes are bad. I have 1 gal of e85 and the rest 93 and pulled timing on all logs on this tank.
03-28-2023, 11:21 PM | #28 | |
Rep 932
03-29-2023, 03:29 AM | #29 | |
B58 Power
496
Rep 630
As far as i know it´s only compatible with the FEMto OBD2 Flasher and bm3, MHD, MG Flasher.
03-29-2023, 07:29 AM | #30 |
Rep 524
MichaelNRW496.00 |
03-29-2023, 08:23 AM | #31 | |
Rep 1,468
Like I said, their tech support has also been wrong in the past. Also I question their recommended plugs and gap.
04-10-2023, 11:03 AM | #33 | |
Joint Chiefs of Staff
24342
Rep 191,109
the AA and MHD are both proven to work well without any major concerns.
04-11-2023, 04:47 PM | #34 |
Rep 193
I’m using an OTS 93 map. How do I check if I’m getting clean timing?
Current car: G20 M340i Black Sapphire (Stage 2 BM3 and xHP with Downpipe)
Previous cars: 2019 VW Arteon (Stage 1+), 2017 Audi TTS, 2015 Audi S3 Sportback, 2006 BMW 335i Coupe |
04-11-2023, 11:05 PM | #35 |
Rep 1,468
04-12-2023, 09:14 AM | #36 | |
Rep 193
From a novice perspective, it mostly it looks like the timing correction is zero, but there are some points where it spikes - but I'm not really knowledgeable on this kind of thing. BM3 Stage 2 E93 OTS, along with XHP Stage 2, sports cat downpipe. https://www.bootmod3.net/log?id=6436...729b2923da51b1
Previous cars: 2019 VW Arteon (Stage 1+), 2017 Audi TTS, 2015 Audi S3 Sportback, 2006 BMW 335i Coupe Last edited by Wet Fish; 04-12-2023 at 11:12 AM.. |
04-12-2023, 09:26 AM | #37 | |
Rep 595
04-14-2023, 03:00 PM | #38 | |
Rep 1,468
04-14-2023, 03:16 PM | #39 |
Rep 193
No. Didn’t do a WOT pull at all. It was pretty sedate driving - my bad, I didn’t know that was what you were meant to do. Will do one and re-upload in a few days or so and share the logs… just wanna help people know if the BM3 map has problems or not.
04-16-2023, 10:11 AM | #40 | |
Rep 193
The first one was a good opportunity, good run through some gears, and does show some timing corrections, not sure if they are good/bad https://www.bootmod3.net/log?id=643c...0b431263ec7f5d Note: It wasn't quite WOT. I didn't realise at the time but I must have lifted off a little. I also tried a second time but had to lift off due to someone changing lanes in front of me. It was mostly WOT, but only only until the gear changed to 4th. https://www.bootmod3.net/log?id=643c...729b710de1cfdb I'd appreciate your (or anyone else's) thoughts. Is that an unacceptable amount of timing correction? There was no knock's detected on either of them, but noticed there was one in my third attempt at a pull - where I also had to lift off again. Roads too busy today. https://www.bootmod3.net/log?id=643c...0b430ec6959db3
04-19-2023, 06:53 AM | #41 |
Rep 193
Update: BM3 team have suggest moving to the 91 map, even though I'm using 99 Octane fuel. It still had timing issues, so they've advised to reduce the boost pressure target, which I've done a few times and yet to try the latest settings (20PSI)
04-22-2023, 01:00 PM | #42 |
Rep 193
Update: not impressed with BM3 support.
Whilst they are responsive, I think they are deflecting from the issues in the OTS map. Initially directed me to the 91 map (rather than 93) despite me using 99 fuel and STILL had timing issues. Told to reduce pressure target twice… still having issues (and oddly it didn’t show a reduced pressure target on the logs). They are putting it down to fuela and asked me to try a different one, but I’ve tried Shell v power and Tesco momentum which are both 99 octane and I think the only suppliers in the UK. So not much hope of getting the stage 2 map to work. I’m wondering if I’ll get timing on stage 1 at this point. Very disappointed so far.
04-22-2023, 03:03 PM | #43 |
Rep 314
Hello, I have to admit that I am hesitating between MHD, Mgflash and bm3, and reading the concerns of the BM3 after sales service I think I have eliminated it from my choice, thanks to you for your feedback that helped me
04-22-2023, 10:15 PM | #44 | |
Rep 207
