05-25-2023, 03:26 PM | #111 |
Rep 362
I find that the software is downloaded but have to wait for the car to tell me it’s ready to install. I was concerned the first time that I could not install it. Then, one day, a message pops up asking me if I want to install it. Having the same issue with the latest update that was downloaded the other day. Checked the car t.his morning for the message it’s okay to install but again, message said, I will be informed when it’s available to install in the car.
2018 MB E400 Coupe
2023 M340i X drive (Mineral White Metallic, Oyster Vernasca Leather, DAPP, Shadowline, PAP, Premium, Cooling & High Perf Tire, Adap M Susp, HK, Drive Recorder, Sensatec Dash) |
05-25-2023, 06:43 PM | #112 |
Rep 1,534
Exact same experience here. Last year the download on the app eventually expired without the car ever initializing the update. This year I am in the same situation currently for about a month now. I tried to manually update in the car and gets the same bogus message to wait for the car to instal it.
Prior's: E36, E46 x2
05-27-2023, 01:45 PM | #113 |
Rep 33
My 2020 M340i has the 11/2022.60 update through the prep process, waiting to be installed. Like others here...never being prompted to install.
At my dealer today for routine maintenance, and was told it's because this update isn't intended for my car. BMW apparently is rolling out versions of software to cars that they shouldn't, and that my car is already using the 'latest version.' Hard to believe that's what a service guy told me... Sooo...guess I'll try the battery conditioning route. Don't know the first thing about that, but will go back in this thread to see what I can find. |
05-27-2023, 01:54 PM | #114 | |
Old Member
65
Rep 196
Drives: M340i, Mineral White
The dealer is talking crap. My 2020 M340i has 11/2022.60 in it, upgraded by Remote Software Download at the beginning of April. It could be the car battery charge state, causing it to not install. If you buy or borrow a charger, make sure that it is suitable for AGM batteries and connect it to the terminals under the hood/bonnet. A CTek MX5 is a good charger. |
05-27-2023, 01:56 PM | #115 | |
General
13679
Rep 20,335
05-27-2023, 02:03 PM | #116 |
Rep 1
I am having similar issues, but get stuck on the 'requirements' for the My BMW app to transfer the RSU from my iPhone.
I am prompted both via iDrive and the app that the upgrade has been downloaded and ready to be transferred. When I turn on the ignition and have the app open, the app says connected via Bluetooth Audio, connected via Apps, but connection required via Wi-Fi. When I go onto iDrive and check, I can clearly see my iPhone connected via Bluetooth Audio, connected via Apps, AND connected via Wi-Fi and the same from my iPhone settings. Has anyone experienced this too, and based on the current thread are people's My BMW apps saying that Bluetooth Audio, Apps and Wi-Fi are all connected to the car? |
05-27-2023, 05:11 PM | #117 | |
Old Member
65
Rep 196
Then it should all work fine. I've done 6 RSUs without any issues at all...4 on my M340i and 2 on my wife's F 40 1 series |
05-27-2023, 05:20 PM | #118 | |
Old Member
65
Rep 196
I do think that the process isn't very user friendly as there are far too many pre-requisites for it to work correctly. And if you use car play or android auto, you should temporarily disable it on the phone to enable the myBMW App to connect to the car correctly |
05-28-2023, 02:32 AM | #119 |
Rep 8
I wonder why BMW doesn't move to a model of allowing updates either from a persons home Wifi or via the cellular network (SIM card) in each car? The whole process of downloading updates via the app - transfer to the car then randomly waiting for the car to update seems antiquated to me. Esp. when you compare the process to a Tesla and other EVs.
05-28-2023, 08:44 AM | #120 | |
General
13679
Rep 20,335
05-28-2023, 08:47 AM | #121 | |
General
13679
Rep 20,335
As far as disabling the CarPlay, and likely AA, that is the opposite of the way it should be done. If you use CarPlay nothing at all needs to be done in order for the transfer to work since the phone is already connected properly. The file will transfer during regular use.
05-28-2023, 11:20 AM | #122 |
Rep 110
UK based G20 LCI (330i) reporting in.
The previous RSU (the first since delivery) and the most recent RSU (last week) were both performed without using the MyBMW App. The App informed me first that an upgrade was available - but the car had already downloaded it - and proceeded to offer installation at the next switch-off. I waited until the car was parked at home before agreeing to installation. Got the usual questions about car being safely parked, etc - then upgrade started after I left the car with the keyfob. App informed me about 30 minutes later that upgrade was successful completed. As per last time - I had to redo some Bimmer Coding as my changes got erased. The download to App appears to be market related - not required in the UK. Regards, Mike. |
05-29-2023, 09:57 AM | #123 |
Rep 255
Drives: BMW 320d g20
I started this post a year ago when an update failed to install. I finally took it to a dealer who manually installed it. The dealer did not have an explanation, merely said common issue. Well a year on, I have received another update. Transferred to car. Same issue.
So it’s either shocking that Bmw are not fixing the root cause or the conspiracy theorist in me says that Bmw are intentionally excluding cars that are out of warranty. Alternatively they are excluding the pre LCI cars. My car is from feb 2019. Of all the people who have reported the issue in recent days, is any of your cars less than 3 years old or pre LCI ? |
05-29-2023, 07:31 PM | #124 | |
General
13679
Rep 20,335
05-29-2023, 07:44 PM | #125 | |
Old Member
65
Rep 196
I don't think that there is a conspiracy on BMWs part or that BMW are not doing upgrades to non LCI or out of warranty cars. I am in New Zealand and I haven't had any issue at all with the process since i got my M340i in January 2020. But it isn't the most user friendly process and the instructions in the MyBMW App have to be followed exactly, and in the right order. I upgraded my M340i to 03/2023.50 this morning in a bit over 35 minutes..no issues at all. I do a few extra things that seem to make it trouble free: I temporarily deactivate Android Auto so that the MyBMW App is the only app using the WiFI direct protocol to the car. I always drive in Sport mode while the file is being transferred from phone to the car. . And I never interrupt the file transfer from phone to car..even though it says you can and it will continue where it left off..minimizes the chance of a file getting corrupted during the transfer. These things have always worked for me and I'm now up to 8 upgrades; 6 on my M340i and 2 on my wife's F40 1 Series Last edited by TikiTourer; 05-30-2023 at 02:36 AM.. |
francton126.50 |
05-29-2023, 07:51 PM | #126 |
General
13679
Rep 20,335
That is not correct. BMW uses Brake Energy Regeneration so the alternator is on a clutch. Charging only occurs when the vehicle is coasting or braking. The exception to that is when the battery falls below a specific SOC, 60% is most often quoted. At that time it will continue charging until the battery reaches a specific SOC, 80% it seems.
05-29-2023, 08:22 PM | #127 |
Rep 1,809
05-30-2023, 02:28 AM | #128 | |
Rep 255
TikiTourer64.50 |
05-30-2023, 02:52 AM | #129 | |
Old Member
65
Rep 196
good luck |
francton126.50 |
05-30-2023, 05:34 AM | #130 | |
Rep 2
francton126.50 |
05-30-2023, 11:27 AM | #131 | |
Rep 129
On my 2021 M340i xDrive, I recently received an check control message notification for a "Left High Highbeam Malfunction". The left headlight and highbeam functioned without any issues even with the error notification. It also seems to have caused a drain on the battery, because I had to jumpstart it after I got that notification. The BMW service center quickly found that it was a software glitch that was causing that false check control message to appear and that it was indeed causing the headlight module to drain the battery. I got updated to 03/2023.53 (from 07/2021.3X) as a solution for no monetary charge as I am still under factory warranty. Seat and mirror positions presets were erased. Shortcut buttons and every other setting was preserved. I didn't have a chance to see what else the new update did from 7/21 but I do see updated graphics on energy flow and the car does seem to charge the 48V battery more often/easily when driving. |
05-30-2023, 01:20 PM | #132 | |
General
13679
Rep 20,335
