Technical Topics Wheels and Tires G30 rims on G20
      06-12-2019, 02:54 AM   #1
Asterix
Asterix's Avatar
21
Drives: BMW 330i G20 Msport
G30 rims on G20
I've checked characteristics of G20 rims vs G30 , and also what is reported by spacer users , it looks like it might be possible to use these rims on a G20 , that would allow tires of 245 and 275 at respectively front and rear.
Has anybody already tried or checked with a rim expert?
      06-22-2019, 02:02 AM   #2
pkancel
pkancel's Avatar
Drives: BMWs
No reason it shouldnt work, if the offset is ok. I had a 2017 G30 540 and wanted to upgrade and put on 2017 750i wheels and they worked perfectly. Gave me the upsize I wanted and fortunately the offset worked well. Thats the only think you would need to be sure of. Is the offset from a G30 with the fitment range for a G20.
      03-09-2020, 04:30 PM   #3
ack720
Drives: G20 3.20i
I am also looking for an advice to fit 664M g30 rims to G20. However, Front:245 and rear:275 is not adviced by BMW
      03-09-2020, 10:42 PM   #4
chenry
Drives: BMWs
Maybe I'm wrong (wouldn't be the first time) but I believe the G30 uses a 5x112 bolt pattern while the G20 uses a 5x120. Did the G30 bolt pattern maybe change
      03-09-2020, 11:03 PM   #5
VipinLJ
VipinLJ's Avatar
All G chassis cars use a 5x112 bolt pattern. The G20 included.
2020 BMW 330i xDrive
2018 Audi SQ5 Prestige
2017 Audi A7 Prestige
      03-09-2020, 11:37 PM   #6
chenry
Drives: BMWs
thank you for the correction - 5x112 makes sense - I stumbled on a couple posts/searches that led me to believe it was possibly 5x120
      03-10-2020, 01:59 AM   #7
ack720
Drives: G20 3.20i
Bolt pattern is the same. However, G20 tyre widths 225/255 and G30 tyre widths are 245/275 and this may cause some problems...
      03-10-2020, 12:44 PM   #8
Asterix
Asterix's Avatar
21
Agree but it looks like some people put even wider tires. I think using BMW rims would be better provided that ET is OK with G20. The rear tires are definitely too slim for this car .
      02-03-2022, 12:00 PM   #9
Hazem Shahin
Drives: BMW G20 320i 2020
hello there bro!....looking to do the same thing ...fitting those G30s on my G20....have you already done it?
      02-03-2022, 12:02 PM   #10
Hazem Shahin
G30 wheels on G20
      02-21-2022, 09:40 AM   #11
greyrevolver
Drives: BMW 320i G20
What the maximum front tyre adviced by BMW?
