03-12-2024, 02:21 PM | #1 |
Rep 561
Does the engine feel the stress of a tune all the time? Or just went in WOT/Boost?
I'm no stranger to tuning, having tuned multiple of my cars over the years and this question over dawned on me. I'll try my best to explain it without sounding like an absolute knob but say there are 2 cars, both cruising on the highway at 8th gear 2.5k RPM 70mph (or whatever the cruising mph may be). Does the tuned car have more stress on its engine vs. the other car running stock factory tune? I'm just wondering if our cars feel stress all the time under tunes or only when building boost or going WOT, if that makes sense.
03-12-2024, 02:25 PM | #2 |
Rep 4,144
depends on the mapping at 2.5k rpm
did the tune disable certain protective parameters did the tuner install a high flow oil filter that fails to filter certain metals did the tuner install a high flow CAI that fails to filter certain dirt did they modify the EGR/PCV in a detrimental fashion there are so many things in the software and the hardware! i think you are asking an impossible question and the answer is it depends what your "tune" changed from stock and is the series of changes detrimental |
03-12-2024, 02:31 PM | #3 |
Rep 311
g21 you're going too far in your mind for a simple question (say jokingly ), so the simple answer is that in normal driving you have no additional bosst and therefore identical, but with each strong acceleration you have the boost.
03-12-2024, 02:32 PM | #4 | |
Rep 561
03-12-2024, 02:34 PM | #5 |
Rep 561
This is what I thought to be the answer. Thank you.
03-12-2024, 03:05 PM | #6 | |
Rep 4,144
that suggests to me they have messed around with the mapping when not WOT unless of course they are all lying, which is possible since most people tell me their mpg is worse even when cruising, but that's another story |
