11-21-2023, 02:16 AM | #1 |
Rep 10
M340i RPM Jump While Cruising
I have a 2019 M340 and it has 75 thousand km. Strangely, when the gas is released in the first 3 gears, my vehicle increases the rpm and then decreases the rpm. I took my vehicle to the service, but they could not detect what was happening. I wonder if anyone who has an idea or has experienced this can help? I tried to put the video in the most obvious way.
http://www.youtube.com/shorts/0En5l47AR_Q |
11-21-2023, 11:04 AM | #2 |
Rep 24
This looks perfectly normal.. Most lower gears will have a “harsher” transition from open to closed throttle especially if you pull your foot off the pedal quickly. This would seem even more dramatic in first gear. Is this affecting your day to day drivability?
11-21-2023, 11:45 AM | #3 |
Rep 10
It does this even at low revs, not just in sport mode. Also, even if I slowly take my foot off the gas, the rpm increases, then the required rpm drops, it increases by about 100 rpm, which is why the vehicle shakes.
11-21-2023, 08:39 PM | #4 |
Rep 24
Do you have video of it doing this in comfort and not in manual mode? I drove my car today and thought of this post and I can recreate exactly what your car does in your posted video. If it does it while not in manual at very low revs then perhaps there is an issue. But the video you posted is 100% normal behavior.
11-22-2023, 12:12 AM | #5 |
Rep 10
It is not normal because I tested my friends' 435 and 340 and there is no such problem. I wonder if it is time to change the oil, or whether it is related to the transmission software or a mechanical problem. New video here.
https://youtube.com/shorts/Zdl_Y2Kpg...j6QExbnXXnefzA |
11-22-2023, 12:24 PM | #6 |
Rep 10
Has anyone experienced this or have any ideas? Do I need to change the transmission oil ? I don't know how clear it is in the video, but the speed increases unintentionally and then the required speed drops, the same thing happens when giving gas or shifting gears.
11-22-2023, 08:08 PM | #7 | |
Rep 714
Do you still have a warranty?
11-25-2023, 12:30 PM | #9 |
Rep 714
Ugh. You can always pay BMW the diagnostic fee and see what the issue is. Confirm the problem. The car will be fine for right now.
11-25-2023, 04:18 PM | #10 |
Rep 10
Unfortunately, the BMW authorized dealer could not find the problem in the vehicle. But I think my problem is due to the solenoid valve. What you said makes more sense.
11-26-2023, 06:15 PM | #11 | |
Rep 714
https://www.e90post.com/forums/showthread.php?t=1318219
