12-20-2021, 04:52 AM | #1 |
iCARMIX
155
Rep 588
BMW G20 320i M Sport with KW ST SUSPENSION ST XA Suspension Coilovers Kit Upgrade
Everyone says that M Sport suspension for G20 this generation was too bumpy for everyday use.
After two years of driving, this car is finally getting an upgrade. Coilover ST XA from ST suspension was chosen this time. Rebound damping can be individually adjusted on the top of the suspension struts. There's 16 distinct click for you to adjust and this car is currently running on 9 click open which is the factory setting for both the front and rear. Ride height can be adjusted from 40-60mm as well. This set of suspension does the job really well and doesn't cost as much as KW suspension, but can you imagine both ST and KWs were made from same factories. Here's some photos for this job. |
Tags |
318i, 330i, g21, g22, hong kong, icarmix, m340i, st x, st xta, suspenison upgrade |
