Technical Topics Wheels and Tires 18inch 662M staggered set on G20
      12-12-2023, 06:51 PM   #1
Almo-G20
Drives: BMW G20
Can I fit the 662M staggered set originaly from 5series on my G20 without issues? So i checked if the 662M set would fit my G20 but did not know that it is a staggered set, noticed after purchase
Sell? or does it fit? I intend to use it as spare winter set
Rim & Tire size 662m
18 inch
front 245/45
rear 275/40
Current setup
18 inch 780
front 225/45
rear 225/45
      12-25-2023, 05:12 AM   #2
320iG20
Stick Shift ftw ;)
320iG20's Avatar
Germany
22
Drives: 320i
The stock G20 18" 790M wheel have the following measurements:
Front: 7,5J x 18" ET 25 tires 225/45 R18 95Y
Rear: 8,5J x 18" ET 40 tires 255/40 R18 99Y
The G30 662M rims are half an inch wider but with the higher offset that fits perfectly.
Front: 8,0J x 18" ET 30
Rear: 9,0J x 18" ET 44
You would just need to change to the narrower G20 tires. The front wheels are half a kilo lighter than the 780, the rear wheels are the same weight. With wider rear tires the car will feel a little more planted - that's a matter of taste.
