2019+ BMW 3 AND 4-SERIES FORUMS (G2x Generation) Local Forums UK Touch up paint
      04-20-2020, 10:04 AM   #1
Tam the Bam
Grumpy Old Git
Tam the Bam's Avatar
443
Touch up paint
Went to apply some touch up paint to a couple of small chips on the bonnet today. Cleaned , sanded (very fine grit) then wiped down with IPA. Dried of the area and made sure it was dry before applying the touch up paint. (BMW touch up paint) with a very fine artist brush.
Problem: The paint just would not adhere to the chipped area it would not cover it at all. I really tried and it did mark up the surrounding paint but the chip did not fill in at all. It was like it was repelling it.
Anyway.....cleaned it all off with some compound using a D/A sander and got it back to how it was before I started.
Any ideas why it wouldn’t adhere to cover the chip..... do I need to prime the aluminium?
Retired:
F10 520D M Sport
E60 520D SE
Volvo S60 type R
      04-20-2020, 03:33 PM   #2
Phippsy81
Phippsy81's Avatar
79
Drives: G20 330i M Sport Plu
If it's down to the metal you should apply primer first yes
J
330i M Sport Plus
Previous- 435D M Sport
      04-20-2020, 04:01 PM   #3
Tam the Bam
Grumpy Old Git
443
Thanks for the response.....
It is hard to say if it is down to the metal (Aluminium) it just looks grey/black which I thought might have been the original primer....
Retired:
F10 520D M Sport
E60 520D SE
Volvo S60 type R
      04-20-2020, 04:27 PM   #4
Phippsy81
Phippsy81's Avatar
79
It could be, but it's probably worth a primer coat either way just incase.... It will stop any issue with oxidising/rust, and give a better contact surface for the paint to adhere to...
J
330i M Sport Plus
      04-21-2020, 07:01 AM   #5
Tam the Bam
Grumpy Old Git
443
That was why I was so surprised the paint would not adhere at all to the surface. It would not even mark where the chip was never mind covering it and then not staying put.
It is for this reason I am at a loss.
Again thanks for your response....
Retired:
F10 520D M Sport
E60 520D SE
Volvo S60 type R
      04-21-2020, 03:16 PM   #6
Isow
319
Drives: G20 330i MSport
Use Chipex, I’ve never had a problem.
      04-22-2020, 01:55 AM   #7
Mattyk
Mattyk's Avatar
591
Drives: G20 M340i
Looks better than trying to repair with the touch up paint brush or a cocktail stick!
G20 M340i
Gone
F36 435d
F30 335d
      04-22-2020, 10:40 AM   #8
aguycalleddb
aguycalleddb's Avatar
450
Drives: BMW G42 M240i XDrive
I've used chipex on mine and it covered the small chips on the bonnet no problem, the BMW one probably needs a primer and lacquer to finish properly
Dan
G42 /// M240i Thundernight
      04-22-2020, 10:51 AM   #9
Tam the Bam
Grumpy Old Git
443
Does it give a good finish?
Retired:
F10 520D M Sport
E60 520D SE
Volvo S60 type R
      04-22-2020, 11:09 AM   #10
aguycalleddb
450
Yeah I'm happy with it, second car I've used it on. Deep chips need a couple of coats but it's easy to apply and colour match is good. I had one at the back of the side skirt which is completely gone and a couple on the bonnet which are hardly visible now, I'll try and get a close up when I was it
Dan
      04-22-2020, 11:22 AM   #11
Tam the Bam
Grumpy Old Git
443
That would be great...... Thanks
Retired:
F10 520D M Sport
E60 520D SE
Volvo S60 type R
      04-22-2020, 01:03 PM   #12
Mattyk
Mattyk's Avatar
591
Drives: G20 M340i
Could be buying this, I have a chip with <700 miles grrrr
G20 M340i
Gone
F36 435d
F30 335d
      04-22-2020, 02:05 PM   #13
Phippsy81
Phippsy81's Avatar
79
I've got a primer, paint and lacquer kit and have done a couple of chips on the bonnet, but it was time consuming and the wet sanding to finish is a bit of a pain, followed by polishing back to a good finish... the Chipex system does look like a good option and pretty user friendly...
J
330i M Sport Plus
      05-04-2020, 05:16 AM   #14
Tam the Bam
Grumpy Old Git
443
Ok seriously looking at the Chipex product for these small deep chips on my bonnet.
As stated earlier in the thread I had no success with the BMW touch up paint
Any advice?
Retired:
F10 520D M Sport
E60 520D SE
Volvo S60 type R
      05-04-2020, 05:27 AM   #15
crazybones
crazybones's Avatar
262
Drives: 718S Boxster, Tesla Model Y
Must admit that I've found Chipex very variable. Certain colours work better than others.
I've now found that the best option for me are the cheap touch up sticks with the ultra fine metal tube tip, so you can feel the chip precisely then subsequently polish with a DA.
Current: Porsche 718S Boxster. Tesla Model Y Long Range
BMW ancestry: G20 M340i, F36 440i Gran Coupe M Sport, F30 330d M Sport (RIP), F30 328i M Sport / E90 330D LCI, 330D, 325i / E46 325i, 320i / Merc 250 D AMG (listed to remind me never to buy another Merc!)
      05-04-2020, 06:41 AM   #16
Tam the Bam
Grumpy Old Git
443
Thanks for the response. That was my plan (with the BMW touch up paint). Paint then use a DA to polish it. However the paint just wouldn’t fill in the chip. It was like it was being repelled. I did have to use the DA to clean up the edges (on paint) where the paint had adhered. Maybe need the primer as shown in the kit in your post.
Retired:
F10 520D M Sport
E60 520D SE
Volvo S60 type R
      05-04-2020, 08:50 AM   #17
crazybones
crazybones's Avatar
262
I'm guessing that you tried something such as lighter fluid on a cotton bud to remove anything in the chip that was repelling the BMW touch up paint?
I tend to find the BMW touch up paint rather thick and the brush too large. Must admit that I am now a convert to these needle tipped touch up kits as it's like using a cocktail stick and you can direct the paint exactly where required.
      05-04-2020, 09:32 AM   #18
Preciseyyc
Preciseyyc's Avatar
Drives: F15 35i G20 m340
No primer needed. Build up the chip. I do dozens a month on client cars. Don't try and fill it in one shot.
Apply super thin, dab it in with a Q tip, let dry fully add more and repeat. Then you can lightly sand and polish.
      05-04-2020, 10:37 AM   #19
Tam the Bam
Grumpy Old Git
443
I cleaned with IPA before trying to apply the paint.
Retired:
F10 520D M Sport
E60 520D SE
Volvo S60 type R
      05-04-2020, 10:42 AM   #20
Tam the Bam
Grumpy Old Git
443
PM sent.... thanks
Retired:
F10 520D M Sport
E60 520D SE
Volvo S60 type R
