2019+ BMW 3 AND 4-SERIES FORUMS (G2x Generation) Local Forums UK How many concrete flags in the boot?
      04-29-2020, 09:37 AM   #1
lukas125
Drives: BMW 330i
As the title says really. How many 40kg concrete slabs do you reckon I can carry in a G20 at one time without bottoming out the suspension?
      04-29-2020, 11:34 AM   #2
aguycalleddb
aguycalleddb's Avatar
450
Drives: BMW G42 M240i XDrive
At a guess 6 - 7, that would be about the same weight as three passengers
Dan
G42 /// M240i Thundernight
      04-29-2020, 01:58 PM   #3
robbiep
1983
Drives: VW e-Golf !
Bottoming out the suspension is only one of your concerns.
Lots of weight at the back = front being high up = far less effective steering.
Having done the same with 200kg or so (in the F31, which is a bit more 'designed' to carry stuff in the boot), I can confirm it's not the most wonderful experience.
Might only weigh the same as 3 rear seat passengers, but the weight is now slung out behind the rear axle, instead of directly above it
      04-29-2020, 04:03 PM   #4
danorman777
danorman777's Avatar
102
Drives: M340i Touring
Found this in the specs for my M340i Touring....
Weight, unladen, to DIN/EU kg 1770 / 1845
Max load to DIN kg 595
Max permissible weight kg 2365
Max axle load, front/rear kg 1095 / 1345
Max trailer load, braked (12%)/unbraked kg 1800 / 750
Max roofload/max towbar download kg 75 / 75
      04-30-2020, 06:01 AM   #5
Karl V
Karl V's Avatar
101
Drives: Sideways
As Robbie says, I'd be tempted to try and even out the load. Maybe using the passenger footwells too if you can (size permitting of course); but I'd def consider laying down the back seats and spreading the load further into the cabin.
Digital drive: F90 M5
Analogue drive: Ariel Nomad
      04-30-2020, 06:55 AM   #6
Tam the Bam
Grumpy Old Git
Tam the Bam's Avatar
443
Agree ... that makes sense....
Retired:
F10 520D M Sport
E60 520D SE
Volvo S60 type R
      05-17-2020, 02:59 PM   #7
lukas125
Drives: BMW 330i
Can confirm 4 flags (total 200kg) is not a problem
      06-02-2020, 09:48 AM   #8
robbiep
1983
Drives: VW e-Golf !
Surely if they are 40kg apiece (as in your original post), 4 flags is 160kg ?
      06-03-2020, 01:06 PM   #9
Seaford
Drives: 840 M Sport Gran Coupe
If anyone is interested I had five bags of builders sand in the boot of my G20 yesterday.
Only wanted two but five minimum order.
You're welcome....
      06-03-2020, 01:54 PM   #10
Karl V
Karl V's Avatar
101
Drives: Sideways
You're welcome....
You'll probably find there's 3 bags worth of loose sand still in there. Gets everywhere doesn't it...
