2019+ BMW 3 AND 4-SERIES FORUMS (G2x Generation) Local Forums UK Automatic recognition of tyres
      05-15-2020, 06:01 AM   #1
Blackers
Blackers's Avatar
62
Drives: 330e
Does anyone know how this works? Is it something a dealer needs to set up?
I have just changed from my winter to sumner tyres and was setting them up on the screen, I went for the manual option and selected the right size for the rears. The automatic option intrigued me.
      05-15-2020, 06:10 AM   #2
Karl V
Karl V's Avatar
102
Drives: Sideways
It does say that auto can only be programmed by a Service Partner. Maybe they blip barcodes and what not to set it (?)
Digital drive: F90 M5
Analogue drive: Ariel Nomad
      05-15-2020, 06:18 AM   #3
Karl V
Karl V's Avatar
102
Drives: Sideways
I did get intrigued through by the Load Status though.
Seems 'Fully Loaded' means vroom vroom rather than 'carrying the In-Laws in the back'???
      05-25-2020, 08:51 AM   #4
ukbeemerboy
Beemer Heaven
ukbeemerboy's Avatar
462
Drives: BMW M4 Competition
If you buy a 3 series in a Germany, they come supplied with a winter set up. This will be configured in the iDrive at PDI and then the car will determine between the two because it’s been told what to expect.
Scott
2018 BMW M4 Competition
2019 Mini Countryman Cooper S : 2008 Mini Cooper
      08-06-2022, 09:03 AM   #5
jd85_m
Drives: BMW G20 330e
For me on a G20 it gives the following recommendations in bars (on the current outside temperature and for a 225/50 R17 98Y):
- Comfort: 2.2 front, 2.5 rear
- Eco: 2.7 front, 3.0 rear
- Load: 2.6 front, 3.1 rear
      08-06-2022, 10:39 AM   #6
Charlie (Wessex)
Drives: G21 M340i
Mine quite often say 2.7/2.8 bar which is 39/40 psi. Michelin say pressures should be 36 psi.
Do you go with BMW or Michelin? At one stage, BMW recommended inflating to more than the max pressure on the tyre sidewall, so I've stuck with Michelin's recommendations.
      08-06-2022, 03:07 PM   #7
HighlandPete
Drives: BMW F11 535i Touring
Are you quoting cold setting pressures, or real time running pressures?
36psi (cold) will be 39/40psi when up to running temperatures.
      08-06-2022, 05:36 PM   #8
Charlie (Wessex)
Drives: G21 M340i
Cold settings.
      08-07-2022, 03:32 AM   #9
HighlandPete
Cold settings.
Your door jam plate is recommending 2.7/2.8 bar for normal use???
      08-07-2022, 05:05 AM   #10
paulockenden
575
Drives: 330e xDrive Touring
That's not unusual.
      08-07-2022, 05:08 AM   #11
paulockenden
575
Having said that, my door plate is completely at odds with what the iDrive recommends. The latter has very similar pressures whereas the door plate shows the rears a fair bit higher.
      08-07-2022, 07:05 AM   #12
HighlandPete
iDrive is recommending real time pressures. Door plate cold settings. Is this not 'adding up' to about 3 - 5psi extra pressure, when tyres are up to working temperature/pressure?
There does appear some logical reason for some unexpected pressure recommendations from the sample door plate. The use of XL tyres is part of it. Is the iDrive menu giving options for standard and/or XL tyres?
      08-07-2022, 07:10 AM   #13
HighlandPete
That's not unusual.
The use of the 19" 93Y XL @ 2.7bar, makes sense to be a high pressure. I've not calculated the xDrive front axle loading, but BMW may be recommending the 2.7 on the 93Y XL, simply on the L.I. capacity, for a given pressure.
      08-07-2022, 10:19 AM   #14
paulockenden
575
My car specifies extra load tyres only.
      08-08-2022, 03:54 PM   #15
Charlie (Wessex)
Drives: G21 M340i
That's not unusual.
That's the one.
51psi!!! My tyres say max of 45psi IIRC - it's late and dark so not going to check, but know 51 is over the max.
Tyres are non-RFT Mich PS4S star marked
