Technical Topics DIYs and Coding Discussions Flashing ECU fail, what should i do?
      05-23-2020, 09:46 AM   #1
kingmag2001
Drives: F20 Alphine White
Any help would be very much appreciated, this is my first time to perform ECU flashing on G series..
Code:
Read SVT before TAL execution started.
ExecutionID=2020/05/23-22:31:33.713
[] prepareTALExecution started [PROGRESS]
[] prepareTALExecution finished [PROGRESS]
[] prepareVehicleForFlash started [PROGRESS]
[] prepareVehicleForFlash finished [PROGRESS]
[DME_BAC2 - 12] prepareECUforFlash started [PROGRESS]
[DME_BAC2 - 12] prepareECUforFlash finished [PROGRESS]
[DME_BAC2 - 12] authenticateECUforFlash started [PROGRESS]
[DME_BAC2 - 12] authenticateECUforFlash finished [PROGRESS]
[DME_BAC2 - 12 - swfl_00005d55-060_120_005] Transaction type: swDeploy;  Message: TA started [TRANSACTION]
[DME_BAC2 - 12] performEcuFlash started with protocol UDS [PROGRESS]
MCDDiagService<id=56634, job=com.bmw.psdz.jobs.uds.MCD3_PerformECUFlash, service=RC_EM_IE - RoutineControl EraseMemory IndicatedErasing, description=error: negative response : conditionsNotCorrect, link=DME_BAC2_12_ETHERNET> [DIAGSERVICE]
[DME_BAC2 - 12 - swfl_00005d55-060_120_005] Transaction type: swDeploy;  Message: 0% progress on ECUId:DME_BAC2_0x12 [0% of swfl_00005d55-060_120_005] [TRANSACTION]
[] job failed with negative response error:
 code: repeat job
 description: Service RC_EM_IE returned a negative response with response code conditionsNotCorrect; LinkName: DME_BAC2_12_ETHERNET
 severity: ERROR
 [THROWABLE]
[DME_BAC2 - 12 - swfl_00005d55-060_120_005] Transaction type: swDeploy;  Message: TA finished [TRANSACTION]
[DME_BAC2 - 12] -MessageID is used multiple times, so MessageText may be ambiguous-job failed with negative response error:
 code: repeat job
 severity: ERROR
 [WARN]
[DME_BAC2 - 12] - [Exception - DME_BAC2 - 12] job failed with negative response error:
 code: repeat job
 severity: ERROR
MCDDiagService<id=230726, job=com.bmw.psdz.jobs.uds.MCD3_PrepareECUforFlash, service=DSC - DiagnosticSessionControl, description=error: negative response : subFunctionNotSupportedInActiveSession, link=DME_BAC2_12_ETHERNET> [DIAGSERVICE]
MCDDiagService<id=64616, job=com.bmw.psdz.jobs.uds.MCD3_PrepareECUforFlash, service=RC_DAFM_AFM - RoutineControl ActivateFlashMode, description=error: negative response : generalReject, link=DME_BAC2_12_ETHERNET> [DIAGSERVICE]
MCDDiagService<id=34727, job=com.bmw.psdz.jobs.uds.MCD3_PrepareECUforFlash, service=CDTCS - ControlDTCSetting, description=error: negative response : serviceNotSupportedInActiveSession, link=DME_BAC2_12_ETHERNET> [DIAGSERVICE]
MCDDiagService<id=276649, job=com.bmw.psdz.jobs.uds.MCD3_PerformECUFlash, service=RDBI_RMA - ReadDataByIdentifier ReadMemoryAddress, description=error: negative response : requestOutOfRange, link=DME_BAC2_12_ETHERNET> [DIAGSERVICE]
 code: repeat job
 severity: ERROR
 [THROWABLE]
[DME_BAC2 - 12] There was an error during TAL execution, please check the log files. [WARN]
 code: repeat job
 severity: ERROR
[DME_BAC2 - 12] finalizeECUFlash started [PROGRESS]
[DME_BAC2 - 12] finalizeECUFlash finished [PROGRESS]
[] There was an error, please check the log files. [WARN]
[] - [Exception - DME_BAC2 - 12] job failed with negative response error:
 code: repeat job
 severity: ERROR
[] finalizeVehicleFlash started [PROGRESS]
[] finalizeVehicleFlash finished [PROGRESS]
[] prepareVehicleForCoding started [PROGRESS]
[] prepareVehicleForCoding finished [PROGRESS]
[] finalizeVehicleCoding started [PROGRESS]
[] finalizeVehicleCoding finished [PROGRESS]
[] finalizeTALExecution started [PROGRESS]
[] finalizeTALExecution finished [PROGRESS]
TAL execution finished [TAL_EXECUTION_FINISHED]
TAL-Execution finished with status: "FinishedWithError". [C207]
TAL execution finished. Duration: "41s". [C206]
Read SVT after TAL execution started.
Read SVT after TAL execution finished.
      05-23-2020, 06:23 PM   #2
mrgicm
mrgicm's Avatar
441
Drives: BMW M
Are you sure the ignition was on? How did you connect to the car with Esys via VIN or direct connection?
What was the reason you wanted to flash your dme?
Your car does not start now? PM me if you need help
      05-01-2021, 11:15 AM   #3
ashikaitc
France
Drives: BMW F30 318i
Hello . did you resolve this issue ?
