Technical Topics iDrive, Nav, Phone, Audio, Video, Cameras, Electronics G22 M440i - passenger seat only moves an inch at a time
      11-30-2022, 06:22 AM   #1
carlr
carlr's Avatar
99
Drives: 2022 G22 M440i
Hi all,
Bit of an odd ball - but taking my chances anyone knows what could be causing this.
I have a MY22 G22 and since a while back, the passenger seat has two issues:
  1. Normally, if you tilt the seat back forward fully, the seat will move to it's most forward position to enable back seat access - this does not work anymore.
  2. When adjusting the seat using the buttons on the side, the seat only moves an inch or so at a time and then you need to release and re-engage the switch and it will move another inch or so.
This really annoying as it makes getting in and out of the back seat a pain for passengers. The drivers seat still works as expected.
Any ideas? Many thanks in advance.
      11-30-2022, 10:26 AM   #2
G22b58
Drives: G22
Does it move with normal speed? (Thinking of over current protection.)
Otherwise what I would try (after reading failure codes with BimmerLink) is if a similar "reset" as is done with windows can help. I.e. drive to endpoints. release and press again a few seconds. Just a wild guess. (It could be some sensor gone bad.)
      11-30-2022, 10:32 AM   #3
drdino
drdino's Avatar
135
Drives: BMW 330i
2019 BMW 330i  [0.00]
Sounds like it's not calibrated and doesn't recognise the track endstops.
