06-29-2023, 01:58 AM | #1 |
Rep 5
395mm or 374mm brakes will fit G20/G21
Hi Guys,
I just bought M340 and would like to do some upgrades, which i can't wait for ;-) I have standard blue m-sport brakes, do you know if it is possible to fit 395mm brakes? I looked online but all i see for G20/21 are 374mm brakes. Many thanks in advance! :-) |
06-29-2023, 08:43 AM | #2 | |
Rep 1,515
07-01-2023, 11:36 AM | #3 |
Rep 5
02-08-2024, 08:53 AM | #4 |
Rep 624
Chubbiejones892.50 |
02-09-2024, 05:19 AM | #6 |
B58 Power
496
Rep 632
If you really want to upgrade, look for the F95 X5M or F96 X6M brakes.
They fit the G2x chassis without adapters. Only the brake disc retaining screw doesnīt fit, but thatīs no problem because you use the bolts anyway. After this i would code the Alpina brake to DSC ECU. Some users upgraded their brakes and didnīt change the DSC / ABS coding without having issues. I would always recommend to code the size that is next to the one used on the car. e.g. the Performance brake can be HO Wort coded with SPBR. The car should know the size of the brake and how to apply it.
blau3er1158.50 Chubbiejones892.50 |
02-09-2024, 01:48 PM | #7 | ||
Rep 624
MichaelNRW496.00 Chubbiejones892.50 |
02-10-2024, 05:02 AM | #8 | |
B58 Power
496
Rep 632
So itīs possible.
Chubbiejones892.50 blau3er1158.50 |
02-10-2024, 05:30 PM | #9 | |
Rep 624
F95 X5M rear calipers and 380mm ///M disc bolt up onto G2x rear hub too - just checked last night. 398mm rears from G11 etc also bolt up, if people want even bigger, but no ///M disc there! |
MichaelNRW496.00 |
02-11-2024, 05:18 AM | #10 | |
B58 Power
496
Rep 632
Already saw your post in the Facebook group :-) So we can use the complete F95 / F96 brake on the G2x? Maybe you could make a small list of parts to use, especially the discs.
02-11-2024, 03:25 PM | #11 |
Rep 624
