10-14-2022, 07:42 AM | #1 |
Rep 102
Winter tires jack points
Hi everyone, I am seeking suggestions when it comes to winter tires.
1) Should I invest in an additional set of winter tires? Will anticipate snowy season. 2) If so, should I purchase and have pre-mounted on a new set of wheels? 3) With the specific jack points, how concerned should I be taking to the local (national brand) wheel/tire service providers? I ask this since a friend was stuck with a flat on his Mustang, and the towing service refused to assist, mentioning he did not want to damage the battery. thanks! |
10-14-2022, 08:02 AM | #2 | |||
Rep 2,012
Drives: 2022 i4 M50
Current: 2022 i4 M50 | 2022 G07 X7
Gone: 2020 F92 M8 | 2020 G07 X7 | 2018 F80 M3 | 2017 F15 X5 | 2016 F16 X6 | 2015 F36 4 series GC |
WABIM6644.50 |
10-14-2022, 11:46 AM | #3 | |
Rep 102
10-14-2022, 04:26 PM | #4 |
Rep 353
I don't think there are central jack points on the bottom due to the battery. I think you can only use the side points with a jack stand under the control arm just in case. Not ideal but if you are careful shouldn't be a big deal
10-15-2022, 03:48 PM | #5 |
Rep 102
[QUOTE=unfoundnemo;29440650]I've always done it, mainly because it means I could do the swap myself
Most modern cars have specific jack points due to all the extra plastic, side skirts, and other cladding under the car./QUOTE] Thanks again.. Yes my first bummer in years so pardon the ignorance. To avoid a potential single point of failure, should I purchase an additional jack or am I reading too much into a standard owners manual warning (p.348) about frequent jack usage? |
10-15-2022, 04:12 PM | #6 |
Rep 102
Good point, I haven't had a chance to eyeball yet.. but manual's visual descriptor makes a bit difficult to discern the config or location of rectangular jacking point recesses. Perhaps proprietary.
10-16-2022, 03:21 AM | #7 | |
Rep 2,511
Years ago I bought a circular rubber jack pad with a rectangular male piece to go into the female BMW jack point. Using this protective pad and a low profile trolley jack I have changed to winters on my RWD BMW'sat home each year without any problems. I doubt it will be any different on an i4. Twice a year doesn't constitute regular usage in my estimation. So, if I buy winters for my AWD i4 I will plan to DIY change. Dedicated winter tyres aren't that useful here in the UK most winters, all seasons would be better on balance… Winters aren't a legal requirement and the vast majority of motorists don't bother. So, if it snows badly these unequipped folk block the roads anyway…
Driving i4 M50 (G26)
Previous 340i Touring MSport (F31) |
10-16-2022, 08:31 AM | #8 |
Rep 353
Standard lift points you can get with a trolley jack, just make sure it's a 3 ton bc it is a lot more weight. Make sure the jack pad is centered so you don't deform it. If your trolly has deep groves etc you may need a small block on top to flatten the surface
10-17-2022, 02:39 AM | #10 |
Rep 2,511
I bought this BMW adaptor on eBay back in 2014.
It worked a treat on a F30 330d and F31 340i changing wheels twice a year. But, 1.8 tonnes vs 2.2 tonnes for my upcoming M50… My jack has raised edges on the metal plate, they bite into the rubber but have not cut it.
10-17-2022, 12:27 PM | #11 |
Rep 102
Ok I located similar rubber pads here. Looks like a small investment into a trolley as well to compliment the OEM will be in order. Thanks
Will see how winter plays out and await comments on tire experiences. |
10-19-2022, 06:30 AM | #12 |
Rep 1,128
I suggest just having your BMW dealership swap out winter wheels and tires. And using BMW Roadside Assistance if required.
23 Audi Q4 e-tron; 23 i4 M50 on order
14 X3 Retired: 20 Tesla Model 3 LR AWD; 17 540i x; 14 550i Euro Del; 11 550i Euro Del; 08 550i Euro Del; 06 330i Euro Del; 04 545i Euro Del; 01 530i Euro Del |
10-19-2022, 07:13 AM | #13 |
Rep 353
Again.... Just snow tires no need to make it too complicated bbs and msw wheels are oe spec and way cheaper. I would be picky about the rubber and make sure it's an ev tire. Fight the urge to listen to the guy at the tire center telling you how good blizzaks are. I would do nokian or Michelin. Or some other EV spec tire. I looked around at load ratings and axle load etc. Most will meet or exceed what BMW is looking for but I wouldn't try to put on anything too lightweight. I have non msport brakes and was surprised how little clearance I had with 18s. So be careful about sizing down. Tire rack is pretty conservative and will make sure you can easily swap them out. I would do something you can run square that way you can rotate them and get a few seasons on them. I've had zero issues on 3 bmw's with them. The dealer is about 1k more and to say a BMW wheel is better spec'd than a bbs is a bit of a stretch.
10-19-2022, 12:31 PM | #14 |
Rep 45
When detailing my car when it first arrived, I took off all the wheels to ceramic coat inside and outside plus ceramic coat the brake callipers and plastic wheel shields.
The i4 is quite low and even though I had a low lift jack it was not low enough to go under the i4. I ended up buying a 3 tonne ultra low lift trolley jack from Costco which did the job. The jacking points (there are 4 near to where the bodywork adjuts all four wheels) have female plastic mountings already in them which key to the male parts of the jacking plugs that BMW use. You can get rubber male plugs or you can get die cast aluminium ones which work very well and are less likely to wobble. Overall, it is fairly easy to change a wheel at a time. |
10-19-2022, 01:39 PM | #15 | ||
Rep 102
And good points UKi4M50 Quote:
