12-12-2023, 08:24 PM | #1 |
Rep 313
'23 M340i-X on Adaptive Suspension recommendations
I wanted to get some help picking out lowering springs and spacers. I definitely want to go lower, but I don't want to risk rubbing. Although I like the look of H&R, I'm nervous I'll run into a risk of rubbing. Is there that much of a difference between Dinan and H&R? Thanks!
12-13-2023, 07:22 AM | #2 |
Rep 420
You shouldn't rub on H&R if you are on stock wheel and tire. I've only seen people rub with a 255 in the front, and it was very minimal at full lock.
12-13-2023, 08:53 AM | #3 |
Rep 43
You will not rub with H&R’s. I am running them with 13mm staggered stock wheels and it sits perfect in my opinion
-Aaron
relentlessone289.00 |
12-13-2023, 09:31 AM | #4 |
Rep 313
12-13-2023, 05:05 PM | #5 | |
Rep 43
Its slightly stiffer than stock but not bad at all. My old 2021 m340 with run flats and no adaptive suspension felt about the same. I believe H&R says 15% firmer than stock which I would say is accurate
-Aaron
12-13-2023, 05:51 PM | #6 | |
Rep 313
12-13-2023, 06:44 PM | #7 | |
Rep 43
-Aaron
12-13-2023, 06:52 PM | #8 |
Rep 313
12-25-2023, 01:12 AM | #9 |
Rep 14
I'm going Dinan since I plan on buying an ADRO lip and don't want that to break on the countless slanted roads I come across while working in DC. I would constantly scrape on my lowered civic and would cringe every time I heard contact
12-25-2023, 10:28 AM | #10 |
Rep 313
I just went with the H&Rs. Heard from a lot of people they regretted going dinan and wanted more of a drop
