07-20-2022, 11:14 AM | #23 | ||
Rep 1,203
Drives: 2023 BMW i4 M50
If that's the case someone designed that cable on a Friday like you said. I would probably cut the plug and put a new NEMA 14-50P plug if everything else fails. Something like this: - Miady NEMA 14-50P Power Plug, 50-Amp 4-Prong 125/250V Straight Blade Angles Dryer Replacement Male Plug https://a.co/d/eeCesAV Or you can call BMW genius or the dealer and show them this impressive piece of engineering. |
07-20-2022, 11:48 AM | #24 | |
Rep 568
Drives: 2019 X5, 2022 i4 M50
Same on my charger, too. I hazard a guess it was done that way so the orientation is correct when you use the charger mount bracket. You’ll rotate/bend charger whip upwards…then boom, it’s correct. That may or may not be the actual reason… but that’s what I’m going with
Current: ‘19 G05 X5, '22 G26 i4 M50
Retired: F15 X5, F80 M3 ZCP, F10 535d, E84 X1, E90 335d, E92 335i, E46 330i, E39 M5 |
07-20-2022, 11:51 AM | #25 | |
Rep 189
2023 BMW i4M50
2022 BMW X5 xDrive45e |
07-20-2022, 12:19 PM | #26 | |
Rep 1,203
07-20-2022, 01:09 PM | #27 |
Rep 352
Im looking at some pics and vids online, it looks like that's how they designed it... there has to be a reason, the germans don't usually leave anything to chance...
fortunately my 14-50 is installed at a 90 so shouldn't be an issue. Last edited by mlanes01; 07-20-2022 at 01:24 PM.. |
07-20-2022, 01:13 PM | #28 |
Rep 189
Did you purchase that from ebay? I just got my production number for my car so just trying to make some plans as well
2023 BMW i4M50
07-20-2022, 01:15 PM | #29 |
I know a thing or 2 about a thing or 2...
3101
Rep 3,470
Drives: E36 M3 Coupe, e39 M5, i3s
You're spending $80k on a car. Go out and buy the Chargepoint unit 'ya cheap bastard!
2019 Imperial Blue Metallic i3s BEV
2003 Le Mans Blue e39 M5 Dinan S1 1997 Alpine White e36 M3 (the old gal) 2013 Mineral White e92 M3 (sold ) 2014 Carbon Black 650i M-sport (sold) |
cruzer6661237.00 |
07-20-2022, 01:22 PM | #30 |
Rep 1,203
I did, but it's available on shopbmwusa.com or cheaper at other retailers like getbmwparts.
07-20-2022, 01:53 PM | #31 | |
Rep 189
Edit: Hmmm can't seem to find it anywhere. Out of stock?
2023 BMW i4M50
2022 BMW X5 xDrive45e Last edited by Ultbruin; 07-20-2022 at 01:59 PM.. |
07-20-2022, 06:29 PM | #32 | |
Rep 1,203
BimmerBahn441.00 |
07-21-2022, 12:06 AM | #33 | |
Rep 189
2023 BMW i4M50
07-21-2022, 07:14 AM | #34 |
Rep 118
before writing off a permanent wall mount charger, check your state to see if there is an incentive for chargers. Here is Massachusetts there is a sizeable rebate for WIFI home chargers...this gives the utility the ability to throttle your charger...but some states have straight up rebates, the same as an EV purchase.
07-21-2022, 08:29 AM | #36 | |
3101
Rep 3,470
07-21-2022, 08:41 AM | #37 | |
Rep 98
07-21-2022, 10:02 AM | #38 |
Rep 1,203
07-21-2022, 10:15 AM | #39 |
Rep 11
The outlet has the potential to be a high-resistance point in the flow of power, generating a lot of heat or sparks - especially if the contacts get loose. A properly hardwired connection is much less likely to start a fire.
There are features of a NEMA 14 socket designed to mitigate those risks compared to a normal NEMA 15 (regular 15 or 20 Amp household recepticals), but stuff happens. |
07-21-2022, 11:51 AM | #40 | |
Rep 568
cruzer6661237.00 |
07-21-2022, 12:16 PM | #41 |
Rep 118
Those NEMA outlets are intended for something being plugged in and staying plugged in...and the high draw from a charger at 48 amps makes a lot of heat, for a lot longer than a Dryer or oven...these plug in chargers have more failure points then normal...do a quick youtube search on EV charger fire or failure...I come from an industry where all you do is mitigate ways that something will kill you, so I tend to be slightly over cautious.
07-21-2022, 01:33 PM | #42 | |
Rep 1,964
As an engineer part of my job is risk mitigation. Hardwired is always preferred.
Arctic Metallic\CF Splitters,Spoiler, Mirror Covers\LED Tails\LSD\Tinted\Coded\Apex SM10-19"\LED Angel Eyes\Gloss Black Grill\Integrated V1\M-Performance Brakes\Cobb Tuned\xHP Flash ->
07-21-2022, 02:26 PM | #43 |
Rep 118
Ideally I would have some type of setup that turns off the sub-panel in my garage when the smoke detector goes off...I am pretty sure the technology is out there with smart devices, and relays and such...I would then need too get a battery back-up for the garage door opener so I could get to the fire...see over cautious.
