08-08-2017, 06:01 PM | #1 |
Rep 56
Anyone gone from a 135i to an NA/NB Miata?
I have a 2013 135is dct.
The car is incredible in so many ways but it's leaving me lacking in a few ways: 1) not a manual 2) can't mod it (because it's too expensive) 3) can't auto-x it (because of #2) I'm thinking of downgrading to an NA/NB miata so that I can: 1) have a manual again 2) mod the hell out of it 3) get into auto-x Will I miss the power? The comfort? The roof? Anyone that's gone from a 135i to a miata have any thoughts? |
08-08-2017, 08:14 PM | #2 | |
Rep 9,160
The Miata was awesome until I had a long, straight highway commute. They're not exactly fast above 70 or so. Jackholes in Camrys or V8 SUVs will walk away from you and be able to cut you off with abandon. The M Coupe was awesome on the highway and a fair approximation of the Miata at about any speed below 70. Just with a much higher penchant for power oversteer and the trailing arm rear suspension liked to try to kill you. The 1er needed a real LSD. It was so tortured on things like Glendora Mountain Road or Mulholland. I always missed the MC when I found myself there in the 135i. I'd easily recommend any generation Miata over an E82 if you do more city driving than highway or have a high tolerance for being the slow car in traffic. They're awesome, balanced cars that will make you a better track driver since you really get a quick sense of what makes you faster and what slows you down. I still miss having mine and consider adding an ND for a weekend car, even with a two year old in the house. |
rovsky27.00 |
08-08-2017, 08:40 PM | #4 |
Rep 9,160
08-09-2017, 04:50 PM | #7 | |
Rep 316
Drives: C63S Sedan|350Z
The s2000 has an aftermarket and a front & rear suspension that's set up better for auto-x than the Miata (also more power). All you would really need to be competitive are tires and shocks. The Miata would need a lot more! |
08-09-2017, 05:14 PM | #8 | ||
Rep 9,160
Sure, the S2k will post faster lap times, an AP1 will teach you a lot more about oversteer, and both AP1 and AP2 will show you much faster speeds than a Spec Miata. But the Spec Miata will let you race against other drivers in equal cars. Oh, sorry, saw your autox comment, you're probably right there. |
08-11-2017, 07:34 PM | #9 |
Rep 1,343
It's not about the numbers with the MX-5. Is that silly grin on your face even when driving at legal speed. There are so many convertible sports car that came and went...MR2, s2000, z , z3, del sol, cheap boxsters....
As the saying goes....The answer is always a Miata. |
08-12-2017, 11:58 PM | #10 |
Rep 114
You should consider a Vett. C6
Stick available on all models. Can be had for cheap. Obscene amounts of well priced parts available. Can autox the hell out of it. |
08-13-2017, 12:20 AM | #11 |
Rep 56
