04-30-2024, 05:46 PM | #574 |
Rep 13
It’s pretty time intensive. It probably took close to five hours for the passenger seat. But I got much faster as I went along. The second one will probably take three. Luckily there’s very little double stitching in the back!
05-01-2024, 12:37 PM | #575 | |
Rep 615
You basically pried out the old part and put in the lidded one? From which sides did you set on the pry tool?
f*ckin' love my car <3
05-01-2024, 01:01 PM | #576 |
Rep 72
When I did mine, I had to start from th back corner. Go across to the curved area. Then up the side and across the front. When I tried starting on the front, I could lift the front a little bit but not achieve anything else.
05-01-2024, 05:03 PM | #577 | |
Rep 5
I started at the left side and managed to pop it a little out before moving to the top and bottom. After that i just pressed in the plastic box in from the middel ( not the lid but from inside the box ). Not sure if posting links here is allowed but i can post it if it’s allowed |
05-02-2024, 06:54 AM | #579 |
Rep 197
Retrofited Homelink (garage door opener) mirror without glass edge .
In my country in EU we don't have this option from factory for 3 series, so if we want it, we need to retrofit it. For my car is part number : 51162472237 |
05-02-2024, 08:33 AM | #581 | |
Rep 72
As for getting it out, I used a plastic trim tool, put some tape down on the silver rim piece and started to pry it out from the bottom right curved section. Once that section popped up I just started to work my way around with the plastic trim tool. After it's out you can just push the new piece into place. Hope that helps! |
05-02-2024, 10:23 PM | #582 |
Rep 1,158
Thank you to relentlessone for selling a high quality decal and shipping in a timely manner. Cleaned/prepped surface using Gyeon Interior Detail which is alcohol based.
05-04-2024, 10:41 PM | #583 |
Rep 209
Drives: 2023 M340i (Build)
Added OE padded Knee pads with Vernasca Leather and Blue Stiching to match the seats and replace the plastic ones.
Got them used since New is absolute robbery. Much better. |
dhock_holiday221.00 Jonesie19.50 |
05-05-2024, 07:56 AM | #584 |
Rep 209
05-05-2024, 01:36 PM | #585 | |
Rep 209
I got mine off ebay barely used but I dont recommend new because the price is crazy for a simple knee pad. Save it for other mods Heres the part numbers for the ones with black leather and blue stiching. 51167911033 51167911035 |
05-07-2024, 11:38 PM | #586 |
Rep 144
Drives: 2021 bmw m340i xdrive
Small detail… great quality. Fast shipping
Finally got the chance to install a few things, G20 center console interior sticker , New vossen forge billet center caps, New ps4s tires, blacked out fender emblems and rear badge. Don’t mind the break dust , 3 words! “ “bmw brakes suck |
05-09-2024, 12:28 AM | #587 | |
Rep 66
05-09-2024, 02:06 AM | #588 | |
Rep 2
I have a 2023 M440i G22 and am also very interested in retrofitting the mirror with garage door opener. How difficult was the installation? I assume that you had to code something? Would appreciate any information. Thanks, Micke |
05-09-2024, 02:24 AM | #589 |
Rep 567
5 year service (glorified oil change) at the dealer with the day before doing my own wipers LOL.
Side note on the wipers: Bosch Aero Twin are a little off, the driver's side fits perfectly, however the passenger sider blade definitely needed massaged to fit properly. |
05-09-2024, 07:10 AM | #590 | |
Rep 197
It is not difficult. It's like 10min of work. You just need to remove plastic frames, disconnect plug and pull down old mirror. By BMW's manual you don't need to code it, but you will have 2 errors in ISTA. BMW say ignore them. You can also code it to be without error. |
Micke7770.00 |
05-09-2024, 10:53 AM | #592 |
Rep 144
Thank you ! Here you go.
Great quality, thick sticker for durability. And the color matches. I was surprised how fast they ship. https://njmdesignlab.com/ |
05-09-2024, 11:32 AM | #593 | |
Rep 72
05-09-2024, 11:35 AM | #594 |
Rep 144
Yes correct !
