2019+ BMW 3 AND 4-SERIES FORUMS (G2x Generation) Local Forums UK Are these G20 myths ??
      07-21-2019, 09:26 AM   #1
Pentop63
Pentop63's Avatar
14
Drives: X4 M40i
Just reading around the net and the User Guide I have posted the following questions to determine if there is any facts behind some of the articles I have read...
1. Does the new front grill of the G20 open and if so when, as I haven’t seen a pic with one open or understand what the criteria is for it to go to the open position ??
2. The user guide states the car can be put into coasting manually, having tried this technique via the paddles many times, I am still unable to make this happen ??
3. If I select the pre air cooling in the winter months will the windscreen defrost at the planned departure time via the mobile app ??
      07-21-2019, 10:21 AM   #2
oldmick
oldmick's Avatar
England
36
Drives: BMW G20 330i Msport
The grill does open, when the engine needs more air.
Don’t know about 2&3.
BMW g20 330i msport
Portimao blue, Technology pack, Comfort pack, Msport+ pack, Premium pack, Visibility pack
      07-21-2019, 01:04 PM   #3
ballisma
Drives: G20 330i
Hi Pentop63
1. All G20 grills open only when the engine needs air, it closed most of time
2. Coasting manually, I have done this, yiu just need to push the gear lever forward without pressing the side button. This puts the car in neutral and allows you to coast, not sure why you would need it though
I use it in dense traffic
3. Sorry., I don't have the answer to that one
      07-21-2019, 01:11 PM   #4
Pentop63
Pentop63's Avatar
14
Drives: X4 M40i
Re the coasting, the car is an auto and this saves fuel when in eco pro mode but sometimes doesn’t engage coasting as the engine uses it to brake when it preparing for a manoeuvre or approaching roundabout, if that makes sense
      07-21-2019, 01:18 PM   #5
claykin
Drives: various BMW
Coasting is a feature of the ZF transmission when you're in Eco Pro mode. Some F series BMWs had this feature as well.
      07-21-2019, 01:31 PM   #6
Bumble
Bumble's Avatar
Drives: BMW 3 series. Aiudi Q3
If you are coasting down a slope in Eco Pro mode and the slope steepens , will the car increase speed (accelerate) ?
      07-21-2019, 02:49 PM   #7
Pentop63
Pentop63's Avatar
14
Drives: X4 M40i
Yes it works fine automatically and kicks in going down a slope but first thing in a morning the same slope it doesn’t kick in which may be related to the eco mode not being available hence the question as would like to force it manually which is described in the manual via the paddles but it doesn’t work ??
      07-21-2019, 03:12 PM   #8
Bumble
Bumble's Avatar
It may be related to the energy recovery system and perhaps its not being functional until the battery is up to a specific percentage of charge much the same as auto stop start does not operate at all times .
      07-21-2019, 04:07 PM   #9
Pentop63
Pentop63's Avatar
14
Drives: X4 M40i
I was thinking the same tbh... would be nice to see a pic of the open grill if anyone has one ?
      07-22-2019, 04:30 AM   #10
HighlandPete
Drives: BMW F11 535i Touring
Two complex systems involved here, heat and energy management. Not always going to be obvious when cold air is necessary, or what the SoC is for the battery.
The third point, we need the auxiliary heating option to get cabin pre-heating in cold/freezing weather. Without it there is no heat source.
Is the auxiliary heating option listed for the G20, in the UK?
      07-22-2019, 06:18 AM   #11
snusnu
Drives: BMW 330e (g20)
nope, no such option in UK
      07-22-2019, 06:41 AM   #12
tricky6
Drives: G20 330e M Sport+
Presume the 330e does have it? Apparently there is the option to pre-heat the car as long as it’s plugged into the mains, using the remote app.
      07-22-2019, 06:58 AM   #13
HighlandPete
Yes, 330e will have pre conditioning, both for heat and cooling.
      07-22-2019, 07:02 AM   #14
HighlandPete
Is that from BMW themselves, or just from the public specs and price list?
I've haven't seen it listed in the brochures, but that has been the case for other models. Whereas the option has often been available as part of the build, if you dig deeper.
      07-22-2019, 07:21 AM   #15
snusnu
I am talking what is on the list in UK site.
It is also not listed as "standard equipment" in my car order details.
as mentioned by others, maybe some versions have it...
      07-22-2019, 07:27 AM   #16
HighlandPete
Just looked on RealOEM, and selected the 320d model. LHD models (for Europe) have the auxiliary heating option, including the full parts listing. RHD, (for Europe) no matching parts...
      07-22-2019, 08:55 AM   #17
snusnu
because, imho, this is applicable/useful in Nordic countries only.
      07-22-2019, 10:28 AM   #18
HighlandPete
BMW have had the option in some model ranges for the UK market. Perhaps there isn't the take up, to make supporting the option worthwhile.
I pre-heat my car with an electric fan heater in freezing conditions. Running the engine, to thaw out windows, is not an efficient way to do so.
We have run auxiliary heating in VW Caravelles for years. They are a bit smelly to use, but with larger cabins to heat are pretty much essential in winter.
      07-23-2019, 04:45 AM   #19
snusnu
my MOndeo has heated windshield - one of the feature I will miss :/
      07-25-2019, 09:05 AM   #20
Sussex_G20
Sussex_G20's Avatar
145
Drives: G20 330i M Sport
Here are some shots of the grills open and closed, when I collected my car today it was 33 degrees so it was a first experience of them moving for the salesman too!
      07-25-2019, 10:53 AM   #21
Bumble
Bumble's Avatar
Obviously the vanes hinge rather than slide. Suppose we will have to all obtain small paintbrushes specifically for the task of keeping them clean
      11-27-2019, 03:50 PM   #22
vaderarmour
Drives: M Sport 320d XDrive
No, pre air cooling will not defrost the windscreen, I have tried this but it didn't defrost anything.
