2019+ BMW 3 AND 4-SERIES FORUMS (G2x Generation) General G20 Sedan / G22 Coupe / G26 Gran Coupe Discussions What is that noise? Identifying rattling noises
      05-12-2020, 01:04 PM   #265
SomeGuy123
Drives: BMW 330i G20
Originally Posted by Giggler View Post
9 month update: the sil-glyde is still working to solve this issue with the first application. I’m thinking about cleaning and reapplying. But I’m betting this issue will solve any weather stripping/rubber seal related noises for the entire vehicle- specifically at the moonroof and doors. I’m glad I discovered this product. Saves me wasted trips to the dealer to have them poke and prod my vehicle and potentially cause additional problems.
Perhaps I’m one of the lucky ones, but this car has been quiet and trouble free after fixing the front speaker rattle and trunk lid creaking in the first couple months after buying it. I’ve never owned a car this solid. To be honest, I expected the opposite.
My trunk has started creaking. How did you fix it?
      05-13-2020, 11:35 AM   #266
Boro74
Drives: 2020 330i M Sport
I used to get the same b-pillar noises, and thankfully the dealer took care of them. Still get some creaking here and there, but it's way better. I put details in this thread:
https://g20.bimmerpost.com/forums/sh....php?t=1686731
      05-15-2020, 11:18 PM   #267
phayze
Drives: BMW
Do you hear the sound even when car is stationery?
Originally Posted by SomeGuy123 View Post
I have tick tick tick sound from upper b pillar. It’s not loud but it still annoying. It seems like the sound is coming from the outside or something to do with the door rubbers. I have spent like a month trying to figure it out. I even took of the upper b pillar cover, then I can hear the sound even more.
      05-16-2020, 01:57 AM   #268
SomeGuy123
No. Only when driving.
But i dont hear it when driving on really good asphalt.
      05-16-2020, 08:40 AM   #269
Delija
VIP
Delija's Avatar
41
Drives: G20 M340i xDrive
Navigation screen is also prone to rattling on bad roads.
Life is not measured by the number of breaths you take but by the moments that take your breath away...
      05-16-2020, 09:02 AM   #270
Lfk
Drives: BMW 3 Series G20
I definitely had a lot of creaking from the back and it was running me insane. Worse at low speed and on bumpy roads. It took multiple trips to the dealership before it was fixed. It came back after a while and they fixed it again. Funnily, I never asked what the problem was! But then I later had a similar noise from the electric roof and this one was from the seals, which they presumably lubricated. That one has a recurred recently. So I would try to see if it's from your door seals. Basically for my roof, they rub against each other and make a creaking noise.
      05-19-2020, 05:21 AM   #271
A6bullet
Germany
337
Drives: 2020 330i Msport
Not a creaking noise.
I took the car in to replace the driver side mirror that decided to suicide itself. Apart from the dealer leaving my car scratched, I noticed that while driving down the highway there was a subtle whistling that was not there before. It come from the mirror area. Yesterday while driving back I just really focused on the mirror trying to figure it out (not recommended while driving lol).
I noticed one of the corders was not really lining up. Got home and started poking around. Turns out the techs did not fully seat the mirror cover so it was slightly loose. Drove it and now the sound is gone.
E36 318ti
E46 320i
E82 135i
F87 M2
G20 330i
      05-19-2020, 08:30 PM   #272
murderedg20
murderedg20's Avatar
Drives: 2019 330i M Sport
Mine was creaking too. Brought it to the dealer twice and they said they couldn't hear it. I told them to remove the rear acoustic seal and now my car is silent. I can PM a video if you want to hear the sound I had.
      05-19-2020, 09:08 PM   #273
greekcs
greekcs's Avatar
Drives: 2020 M340i xDrive
my steering wheel creaks when any pressure is applied. I've pinned it down to the metallic button surround rubbing against the leather.
2015 09/14 Alpine White on Red 435i xDrive MPPK - Expensive black vinyl with special lettering. SOLD
2020 12/19 Mineral Gray Metallic on Black Vinyl interior M340i xDrive
      05-21-2020, 02:31 PM   #274
ashokgadeking
Drives: BMW M340i
I posted previously on this thread with the fix. The creaking is caused by the rubber seal at the base of the rear glass. You can silence this creak by applying some foam tape along the length of the trunk lid where the rubber seal makes contact with the trunk lid.
      05-21-2020, 02:38 PM   #275
ashokgadeking
Drives: BMW M340i
Here is the image I posted earlier. You can see the indentation in the foam tape made by the seal.
      05-24-2020, 04:25 AM   #276
rockhach
rockhach's Avatar
12
Drives: Bmw 330i g20
I know what the creaking is....
Originally Posted by CyclingBroStyle View Post
Had the car for 2months now. There is a rattling noise coming from either the trunk or back seats anyone had any luck identifying the mystery creaking sound in their G20??
I have the same rattling noises coming from my G20. I figured out it's actually the lid in the boot moving up and down that covers the space where the spare wheel should have been
      05-27-2020, 11:57 AM   #277
Ryshade
Indonesia
Drives: BMW G20 320i
Hi guys, do you know what this metallic clunking sound is?
link to the video
I heard this first time 2 months ago, and has not been able to get it checked due to the pandemic lockdown. car is still new at around 4300km .
happens all the time during idle, cold or hot..
could this be the wastegate rattle?
      05-27-2020, 12:39 PM   #278
Giggler
Drives: 20' M340i, 24' X5 40i
there is a piece of weather stripping along the back of the trunk lid opening... if you follow the comments in this thread it will be obvious. Take sil-glyde and smear a thin layer of it along this piece of stripping and the creak will go away. The other option is to have it removed completely by the dealer, but my argument is that they put it there for a reason.
      06-25-2020, 01:38 PM   #279
GolanTrevize_86
Spain
Drives: BMW G20 320i B48B20B
Originally Posted by dmi2 View Post
I'm hearing rattle from the dashboard, left side, near the A-pillar. If I press down hard on the dashboard near the window, the noise stops. Anyone else with this problem? See video, you can hear it clearly from 8 seconds. Really annoying
vimeo.com/409545851
Had the exact noise, its driving me nuts. Where do you press exactly? I can't figure where ir is while im driving.
Thanks in advance.
For creaking noise from B Pillars i used the same PTFE grease that i used in the trunk for the rubber where both plastics in the door (shadow black) are attached and it works perfectly. As the noise from the trunk I applied the grease long time ago and didn't appear again.
Thanks!
      06-25-2020, 04:14 PM   #280
SomeGuy123
Thanks in advance.
For creaking noise from B Pillars i used the same PTFE grease that i used in the trunk for the rubber where both plastics in the door (shadow black) are attached and it works perfectly. As the noise from the trunk I applied the grass long time ago and didn't appear again.
Thanks!
Where do you put grease on b pillar? Can you take a picture of that area?
      06-27-2020, 04:37 AM   #281
GolanTrevize_86
Spain
I ll take a picture later. Its at the driver/passenger door the black shadow plastic in the upper zone of B pilar. At the door, not the real B pilar. At the outside.
Edit: Right here
      06-27-2020, 04:50 AM   #282
Sergeant Skinner
Sergeant Skinner's Avatar
166
Drives: 2020 BMW M340i XDrive
3 months in and mine is as solid as a rock... except for the steering wheel which creaks when I turn it (or grip tightly in sport plus).
Can't think of what to do about it but it's driving me (pun intended) nuts as it's something you constantly touch!
      06-27-2020, 08:52 AM   #283
jamesw2033
Drives: BMW G20 M340i xDrive
Buzzing Vibrating Noise from Driver side A pillar
I've driven my brand new, 3 week old M340i xdrive for just over 200km when I started hearing a buzzing, vibrating noise, everytime the car moves at any speed. The car has been fitted with acoustic windows which accentuates the noise in the otherwise quiet cabin. This noise is perplexing as I don't know what's causing it but seems to originate around the area of the A pillar on the drivers side.
Wondering if anyone else noticed that in their new G20.
      06-27-2020, 09:04 AM   #284
GolanTrevize_86
Spain
Like in the video of @dmi2 ???? Mine does it only in bad roads but is exactly same noise. He uploaded a video to VIMEO.
      07-01-2020, 11:52 AM   #285
klokan
Drives: BMW G20 330i, Portimao Blue
Edit: Right here
There are many places on this pic where you can put grease.
Did you take black shadow trim off or... ?
      07-01-2020, 12:14 PM   #286
GolanTrevize_86
Spain
No I didn’t. Only leave a little with the spray (sorry English is not my native language) with the cannula where the vertical trim and the horizontal one meets, covering with a paper to not stain everything in the process.
If you press both you will hear a cracking noise which should disappear after.
