Technical Topics Cosmetic and Lighting Modifications (exterior & interior) Replacement windshield fluid cap
      06-04-2023, 01:13 PM   #1
Printertom
Printertom's Avatar
155
Drives: 2020 M340i xdrive Tanz Blue
I'm dressing up my engine and wanted to know if there is a billet blue windshield fluid cap out there...
      06-04-2023, 01:36 PM   #2
pdxdbo
pdxdbo's Avatar
331
Drives: G20 330i xDrive M-Sport
Subb’d because I haven’t been able to find one. The G8x used a different neck and cap. The F30 is larger and fits over the neck in a way that doesn’t seal. I believe with some modification (an inner gasket of some kind) the F30 could be made to work.
      06-04-2023, 10:44 PM   #3
Printertom
Printertom's Avatar
155
Bump
      06-05-2023, 08:16 AM   #4
1QuikWS6
No 55mph
1QuikWS6's Avatar
1622
Drives: F32 435ix MSport
I used the Blackline Caps from GoldenWrench Supply on our Portimau Blue M440
IDK if the M340 has the same style as the 440, but the Cap for G8x series fits perfectly. You simply remove the OEM cap and the aluminum one has an o-ring and installs/seals into the neck perfectly
F32 435ix//MGM//M Sport-Prem-Tech-Driver Assist-Lighting-Cold Weather-Dyn Handling Pkgs//M4 Black Lthr Int w/M4 Alum Blade Trim//HK w/Bavsound Stg3//763M//M4 Euro LCI Tails//M4 Mirrors w/CF Covers//AWCarbon CF F/R Spoilers-Side Splitters-Diffuser 6WB/ID6 HU+HUD/IND M4 Alcantara Armrest//PURE S2 Turbo//AA FMIC+DP//ER CP+TIC//3.5bar TMAP/TS DV//AWE Tuning Exh w/Blk Tips//Turner MS CF Intake//BM3 Cary Jordan Tune//MPerf Diff//PrecRW Ignition Kit
      06-05-2023, 09:22 AM   #5
Printertom
Printertom's Avatar
155
The g20 looks different
      06-05-2023, 12:20 PM   #6
AM340iMiami
AM340iMiami's Avatar
219
Drives: 2020 BMW M340i
Not to highjack the thread but I don't get why the 440 got the strut braces and M340i didn't.
jpowers36218.00
      07-05-2023, 07:35 AM   #7
B58-M340iX
Drives: 2021 M340i xDrive
There are threads on retrofitting this here on the forums if you're interested.
      07-06-2023, 06:41 AM   #8
pdxdbo
pdxdbo's Avatar
331
I ordered and tried this one (same as the S58/G8x) but it's too small for the G20. I ended up retrofitting an F30 cap by using a larger gasket.
1QuikWS61621.50
      07-13-2023, 12:24 PM   #9
Zeros
Drives: 2023 330e & 2013 528i
Yeah, for under $100 you can have them too. I did the retrofit. Super easy.
      02-27-2024, 08:03 AM   #10
Printertom
Printertom's Avatar
155
Found one finally....see link
https://precisionraceworks.com/produ...RoC7kAQAvD_BwE
