02-10-2022, 05:35 PM | #243 | |
Rep 7
i need move code ambient light .. plese help me |
MAGugs1.50 |
02-10-2022, 06:32 PM | #244 |
Rep 7
G ambient light
02-10-2022, 07:10 PM | #245 | ||
Rep 38
You can try this HEX (for pink): 7A005C or 85004B |
02-13-2022, 10:27 PM | #246 |
Rep 3
00, 1A, 01, 90, E0, 90, FF, 02, 90, E0, 90, 00, 03, 90, E0, 90, FF, 01, D7, 6E, 14, FF, 02, D7, 6E, 14, 00, 03, D7, 6E, 14, FF, 01, 93, 1A, 01, FF, 02, 93, 1A, 01, 00, 03, 93, 1A, 00, FF, 01, 00, 20, FE, FF, 02, 00, 20, FE, 00, 03, 00, 20, FE, FF, 01, 10, FE, 32, FF, 02, 10, FE, 32, 00, 03, 10, FE, 32, FF, 01, 78, 3C, FE, FF, 02, 78, 3C, FE, 00, 03, 78, 3C, FE, FF, 02, 00, 00, 00, FE, 01, 96, 00, 00, FF, 02, 96, 00, 00, 00, 01, 00, B0, 60, FF, 02, 00, B0, 60, 00, 01, 00, 00, 00, FF, 02, 00, 00, 00, 00, 03, 00, 00, 00, FF, FF, FF, FF, FF, FF, FF, FF, FF, FF, FF, FF, FF, FF, FF, FF, FF, FF, FF, FF, FF this my car
please change it for me ,thanks |
02-14-2022, 06:07 AM | #247 | |
Rep 38
02-27-2022, 01:52 AM | #248 | |
Rep 14,141
Drives: G82 M4C X-Drive
Keep in mind there is a bug for the map light, which doesn't like FF for some reason. It will not come on when you start the car, only when you toggle to another color then back in the iDrive. Use FE instead of FF. The difference is barely detectible to the human eye.
02-27-2022, 01:56 AM | #249 | |
Rep 14,141
https://www.w3schools.com/colors/colors_rgb.asp
03-13-2022, 04:04 PM | #250 |
Rep 771
pink is fe00c8
2020 BMW M340ix Dravit Grey
2018 BMW M3 Alpine White Last edited by ssgm1x; 03-13-2022 at 04:27 PM.. |
03-13-2022, 04:34 PM | #251 | |
Rep 771
Is it the last group of bytes (13,14,15)?
2018 BMW M3 Alpine White |
03-13-2022, 04:43 PM | #253 |
Rep 771
You tried all 3 and none worked for you ?
03-17-2022, 04:20 PM | #254 |
Rep 38
All three HEX code give the same visual effect
03-17-2022, 04:25 PM | #255 | ||
Rep 38
03-29-2022, 02:11 PM | #256 |
Rep 771
How do I change the all White ambient light color option to Hot Pink ?
03-29-2022, 03:24 PM | #257 |
Rep 14,141
If you change the white bytes, they will change on all the white programmed menu selections. Ie blue and white will become blue and pink, bronze and white will become bronze and pink etc.
03-31-2022, 01:25 PM | #258 | |
Rep 771
Do i change BYTES 3 to ef, 4 to 00, 5 to ee, 8 to ef ,9 to 00,10 to ee, 13 to ef, 14 to 00, 15 to ee ?
03-31-2022, 03:13 PM | #259 | |
Rep 14,141
Yes, that looks right. I used this for PINK: FE 00 FE which is a "purer" pink, but probably visually indistinguishable to what you are using. So my white bites are: 3 FE 4 00 5 FE 8 FE 9 00 10 FE 13 FE 14 00 15 FE
ssgm1x418.50 |
03-31-2022, 03:14 PM | #260 | ||
Rep 38
All HEX code give you the same visual effect All this code are pink: 7A 00 5C 85 00 4B FE 00 C8 EF 00 EE |
ssgm1x418.50 |
03-31-2022, 03:17 PM | #261 | ||
Rep 771
03-31-2022, 03:20 PM | #262 | |||
Rep 771
03-31-2022, 03:37 PM | #263 | ||||
Rep 38
Compare your pink ( EF 00 FE) after coding and mine pink ( 7A 00 5C) after coding. |
ssgm1x418.50 |
03-31-2022, 03:39 PM | #264 | |||||
Rep 771
Thanks 🙏
