02-07-2023, 04:43 PM | #1 |
Rep 25
Tips/Advice for first time installing AA catted downpipe?
Just got my AA catted downpipe and I plan to install it myself over the weekend. I was wondering if you guys have any tips to make the install more smooth and easier. I'm also wondering if there is enough clearance to take the downpipe out with jack stands or ramps. How tall of jack stands do you guys recommend? Thanks!
02-07-2023, 07:03 PM | #2 |
Rep 234
Tips. Remove your airbox, o2 sensors, and the bracket bolts from the top. Loosen the v clamp. Jack up your car and secure it. Loosen the clamp, remove the hanger bolt. Once done you'll be able to separate the downpipe from the exhaust. Hope this helps.
TheJungatron358.00 raannathr33327.50 |
02-08-2023, 10:11 AM | #4 |
Rep 56
I did it myself, took around two hours, car on jack stands, first time changing downpipe. I would rate the overall process as "very easy" with the exception of taking OEM downpipe out as there was almost zero play in the exhaust. I have X3 m40i but my reference was some random video on youtube of a guy changing downpipe on his m340i and they are identical
02-08-2023, 12:57 PM | #5 |
Rep 853
Drives: 2020 BMW M340i xDrive
Once you have the OEM downpipe removed and ready to install the AA, secure the downpipe from the turbo to exhaust. Make sure it’s lined up and fully seated at the turbo, tighten clamp, then work your way back tightening things.
I did it in reverse (exhaust to turbo)my first go round. Ended up having to re-do it cause I was leaking exhaust from the turbo. Wasn’t enough to throw codes, but couldn’t drive with the windows closed.
02-09-2023, 01:21 AM | #6 | |
Rep 25
02-09-2023, 10:24 AM | #7 | |
Rep 853
02-09-2023, 10:39 AM | #8 |
Rep 300
i did it myself with jackstands and it was pretty easy, the toughest part was my v-band clamp was sort of stuck on the turbo, but after messing with it for a while, i was able to get it off.
02-09-2023, 03:30 PM | #9 |
Rep 25
Thanks for the help! How did you notice the leak from the turbo? Was the smell really bad?
02-09-2023, 07:53 PM | #10 |
Rep 853
It was noticeable in cabin when at a stop and the windows closed. I thought it was cat settling at first, until it wasn’t going away. I was able to see faint whisps of exhaust coming from the behind the turbo when I looking under the hood. No matter of tightening the V band made it go away. So ended up redoing the whole install and it’s been fine since.
09-16-2023, 08:33 PM | #11 | |
Rep 82
09-17-2023, 10:36 AM | #12 |
Joint Chiefs of Staff
24317
Rep 191,040
If it's a stong smell, then its a leak. It should be minimal to no smell with the high flow catted AA.
GOLDPHO3NIX22.50 |
09-17-2023, 10:54 AM | #13 |
Rep 82
Thanks Mike! The smell is strong but took some pics. Does this look good?
09-17-2023, 11:44 AM | #14 |
Rep 234
Did you intentionally loosen the clamp to take a picture or is that how it's currently installed?
koopa119.50 GOLDPHO3NIX22.50 |
09-17-2023, 03:18 PM | #15 |
Rep 87
Drives: '23 M240i xDrive
GOLDPHO3NIX22.50 |
09-17-2023, 03:20 PM | #16 |
No 55mph
1622
Rep 8,476
And did you remove the original gasket that sometimes sticks up in place when removing the oem DP?
F32 435ix//MGM//M Sport-Prem-Tech-Driver Assist-Lighting-Cold Weather-Dyn Handling Pkgs//M4 Black Lthr Int w/M4 Alum Blade Trim//HK w/Bavsound Stg3//763M//M4 Euro LCI Tails//M4 Mirrors w/CF Covers//AWCarbon CF F/R Spoilers-Side Splitters-Diffuser 6WB/ID6 HU+HUD/IND M4 Alcantara Armrest//PURE S2 Turbo//AA FMIC+DP//ER CP+TIC//3.5bar TMAP/TS DV//AWE Tuning Exh w/Blk Tips//Turner MS CF Intake//BM3 Cary Jordan Tune//MPerf Diff//PrecRW Ignition Kit
GOLDPHO3NIX22.50 |
09-17-2023, 08:10 PM | #17 |
Rep 82
Thanks for all the replies!
I loosened the vband to take a pic. I’m just wondering if the gap in the pic is really a gap. I installed the supplied gasket from AA. OEM dp gasket is stuck to the OEM DP so good there too |
09-18-2023, 08:34 AM | #18 | |
Rep 829
When you install you AA loosen the bottom downpipe where it connects to the exhaust. Tighten V band first and after tighten bottom exhaust. What happens sometimes is you tighten bottom and it can not fully connect on Vband connection, because its already tighten in place and can not move. I also had a small gap between turbo and downpipe. After doing what I mentioned vibration was gone. Also what torque spec you are using to tighten Vband?
Current: 2022 BMW M440gc / 2022 BMW x5 45e
GOLDPHO3NIX22.50 |
09-18-2023, 01:19 PM | #19 | |
Rep 82
totalone275.50 |
09-18-2023, 02:30 PM | #20 |
Rep 829
There is a gasket? I didnt had no gasket
09-18-2023, 08:08 PM | #22 |
Rep 829
wtf I had no zip on it. perhaps it was already applied or something. I mean it is working as expected and I dont see any leaks. I do smell a little on start up but I think its normal
