10-09-2021, 01:14 PM | #1 |
Rep 34
microphone not working after adding subwoofer
Hi all,
I just installed a amp/sub combo using the technic PnP harness, but the internal microphone stopped working after (so the voice command does not pick up any voice, neither does siri in apple car play). The sub and sound system otherwise works as it should. Has anyone else encountered this problem before? Wanted to check in before I undo the harness and see if this reverses the issue. |
10-10-2021, 01:25 PM | #3 |
Rep 34
I resolved the issue. feel pretty stupid but hopefully this might help someone else. I added the harness to the top module (RAM i think?) instead of the bottom module (bass boost) in the HK 688 configuration. Didn't realize this bottom module existed becuse you have to remove the plastic tray with the tool kit to be able to visualize it.
11-01-2021, 09:49 AM | #7 |
Rep 34
