07-05-2021, 11:22 PM | #1 |
Rep 467
Front Grill below number plate
Someone backed into the front of my car and their tow bar knocked my grill and cracked one of the holes. You wouldn't even notice it unless I pointed it out.
Insurance company sent me to a panel beater and they want to keep the car a whole week to fix it. Is this really a whole week job to replace the plastic grill? |
07-06-2021, 03:18 AM | #3 |
Rep 222
A week is a bit long, but if they need to remove the bumper then it's likely days. The amount of electronics / sensors to disconnect and reconnect on a relatively new car... That they probably have never worked on, will take time to not screw up.
07-06-2021, 07:00 PM | #4 | |
Rep 467
I am hoping the gave me the worse case scenario |
07-06-2021, 10:32 PM | #5 | |
Rep 70
I would want to take it to a BMW specialist so they know what they are doing when removing parts . As it is not your fault and assuming you have the other drivers details they should supply you with a free car. |
07-06-2021, 10:49 PM | #6 | |
Rep 467
07-08-2021, 08:38 AM | #8 |
Rep 467
You won't believe it someone backed into the back of my car at the market, and again the person didn't stop. Again an eye witness came forward and gave me the rego number and the Police have contacted the person.
What is wrong with people being dishonest and thinking they can get away with it. Now I have have to get the back bumper painted along with a new grill - very annoying |
07-09-2021, 04:08 PM | #9 | |
Rep 681
You’re only saving grace is that you can get both ends repaired at the same time. One week of pain instead of two. You’re lucky a witness was kind enough to pass on the Rego of the driver. If he hadn’t be around……….. Maybe it’s time to activate Drive Recorder???
07-09-2021, 07:12 PM | #10 | |
Rep 467
Without looking it up, how does driver recorder work? I will do some investigation into it. EDIT I found this video: Last edited by Michael BD; 07-09-2021 at 07:20 PM.. |
07-11-2021, 04:55 PM | #12 |
Rep 681
This is a quote from BimmerTech.
The last paragraph suggests that a parking accident will be recorded on Drive Recorder once you put your car in reverse. The key is….. it is only after an accident gets detected by the crash sensors that the footage is saved. Automatic recording From the moment you enable camera recording, the BMW Drive Recorder will film unstoppably. However, it is only after an accident gets detected by the crash sensors that the footage is saved. The maximum length of recordings takes only up to 40 seconds – 20 before the accident happens and 20 after – which are the most relevant developments of the event. Taking such video later to court may help with accident reconstruction, and clarifying the cause or who’s guilty. Many people also wonder whether the BMW Drive Recorder works in parking mode. Yes, it can do that. Once you put your car in reverse, the Parking View will be filmed and saved in case of car damage.
07-23-2021, 12:26 AM | #13 | |
Rep 467
