07-06-2021, 04:09 AM | #1 |
Rep 255
Drives: BMW 320d g20
door panel needs repainting
hi guys
the rear passenger door on my 320d was heavily scratched by someone. the panel will need to be repainted? the prestige body shops are quoting 4.3k for the paint job while the regular body shops are quoting 2k. any risks with going with a regular body shop? |
07-06-2021, 06:51 AM | #2 |
Rep 222
I'd get a detailed quote from both to figure out why it's double the price. Seems excessive though, I paid $500 for my front bumper and it was scratched pretty bad.... and I'd suggest harder than the door.
07-06-2021, 04:51 PM | #3 |
Rep 255
they have both provided detailed quotes. I may have to go with the regular body shop. any other risks to be considered apart from the quality of the paint job? I hope there won't be any issues with the electronics as I think that is the key difference between a beemer and a Hyundai
07-06-2021, 07:05 PM | #4 | |
Rep 467
07-06-2021, 08:16 PM | #5 | |
Rep 222
There aren't a lot of electronics in the door - I've pulled mine to pieces replacing all the audio. That's if they are intending on taking it off and painting the internal panels, which seems unlikely. In the end, if you don't like the job then don't pay and make them do it again. As long as the cheaper are reputable you should be fine. |
francton124.50 |
07-06-2021, 10:23 PM | #6 |
Rep 70
My comments assume you have a metallic colour of some sort.
If the door has scratches on the paint ( no dints) the door doesn't have to be removed or painted on the inside . Unfortunately because it is the rear door they have to paint the front door and the rear 1/4 panel and that's where the work is. The rear lights have to be removed and the roof mould so the strip between the window and the mould can be painted all the way to the front guard. The mould on the windscreen has to be removed. The only panel that will be painted in full colour will be the rear door, front, door and 1/4 panel will be blended then the lot cleared. Ask them both exactly what they intend to do in detail. The more expensive job is not necessary better than the cheaper one.. When you get the car back take a good look on the panels to make sure you can't pick the different colour. If the painter is any good you shouldn't be able to tell. Don't look at the panels close up, look from a distance in good light both in the sun and shade. AustraliaG20, a front or rear B/bar is different story. They don't have to blend that, plastics are slightly different colour from factory, so they only need to paint the B/Bar. |
francton124.50 |
07-07-2021, 12:06 AM | #7 |
Rep 305
What colour is your car?
Some colours are super hard to match (for example, metallic white, dravitt). I'd go with a BMW recommended repair shop. |
07-07-2021, 09:52 PM | #8 |
Rep 255
I got another quote from a local body shop that I have used before. they has done an excellent job on my previous mx5 and Tuscon. they showed me beemers that they have fixed previously. $1300. I think I'll go with them and pray that the electronics don't fail me
09-28-2021, 02:58 PM | #9 |
Rep 255
Cranbourne body works did a great job on my car. really happy. nicely colour matched, no issues with the car.
