08-17-2021, 08:01 AM | #25 |
Rep 517
Don't you have a computer, Mac or Win? Just download to the desktop, unpack the file, and copy the the contents of the folder over to the USB stick.
The thumbdrive must be formatted in Exfat.
Previous BMWs: 330e Touring xDrive (G21, 2021), 330e (G20, 2019), 530e (G30, 2018). |
08-17-2021, 08:29 AM | #26 |
Rep 380
From what I understod, he is size limited for the temporary storage.
(Time for a USB HDD then for the temporary storage, provided 2 USB ports are available.) Either NTFS or EXFAT can be used (I have used both). |
eddiehaug748.50 UnluckySaxon62.00 |
08-17-2021, 06:24 PM | #27 |
Rep 4
Hey guys, I am new to the forum. I am downloading the new update. After it validates, I am left with this white box and I am stuck what to do now.
I have downloaded the map and validated it about a dozen times, but still get the same screen. Does anyone know what I am doing wrong? Any help would be greatly appreciated. Thanks. https://i.ibb.co/sKGSZM1/Capture.png Last edited by ChrisButterfield; 08-17-2021 at 06:29 PM.. |
08-17-2021, 08:21 PM | #28 |
BEAST? ... How dare you.
444
Rep 416
For the future, since this is a multinational board, please put EUROPE in the header as to avoid a ton of confusion.
______________
1973 Porsche 911S 2023 BMW M550i 2023 BMW X5M 2020 BMW M340i (retired) |
08-17-2021, 11:01 PM | #29 | |
Rep 380
(Note: My map data is called Europe Live ...) |
08-18-2021, 03:26 AM | #30 |
Rep 276
Drives: BMW G20 330e M Sport
I ended up buying a new €8 64gb usb stick off Amazon 2 weeks back. Worked straight away. Plugged into USB port by the cup holders. Would post a link to it, but just seen it's now €40
08-18-2021, 04:15 AM | #31 |
Rep 517
Done. Not that Americans care about indicating something is specific for the US anyway, but I get your point.
08-18-2021, 04:26 AM | #32 |
Rep 190
As in you downloaded directly to it and it worked without any BS that I'm going through?! 40 euros seems cheap for that luxury!
08-18-2021, 04:41 AM | #33 | |
Rep 276
XLYNE SWG 64GB USB-stick (USB2.0, Plug & Play,Swing) zwart, 177533-2 https://www.amazon.nl/dp/B07WWGF1XS/..._LWFHIthKm27mD |
08-18-2021, 04:48 AM | #34 | |
Rep 4
08-18-2021, 04:52 AM | #35 |
Rep 380
Unlucky..., My instructions were explicit which said to point the temporary download folder NOT to the USB stick that will be used in the car. Step 2, after validating the temporary download it asked me to point out the USB stick to transfer the download to.
Jase500.00 |
08-18-2021, 04:56 AM | #36 | |
Rep 380
Is the USB stick formated in either NTFS or EXFAT? Is it large enough? |
08-18-2021, 04:56 AM | #37 |
Rep 190
I'm not trashing your instructions, bruh (I appreciate them) .... Just asking for further info on someone else's experience. I Thank thee
08-18-2021, 06:21 AM | #38 | |
Rep 380
I don't know the reason, but perhaps it could work if you create a "temp" folder on a stick that is large enough to hold both the temporary and the final product (so about the double size). |
UnluckySaxon62.00 |
08-18-2021, 07:40 AM | #39 |
Rep 517
1. Click on Select Folder and point it to your desktop as a Temp location.
2. When it finishes downloading the files and asks you to insert a USB drive, simply cancel. 3. Unzip the file and you'll get a folder. 4. Copy the files inside that folder into an empty USB drive. 5. Connect the thumb drive to the USB port under the arm rest (though maybe the one beside the cup holders works as well, I don't know). 6. Accept the prompt on iDrive to start updating the maps.
UnluckySaxon62.00 ChrisButterfield1.50 |
08-18-2021, 09:35 AM | #40 | |
444
Rep 416
And if it were location-specific, like maps, I'd definitely put that proper in the header. But, that's just me.
______________
08-18-2021, 10:37 AM | #41 | |
Rep 4
So basically, is the box is white simply because it cannot detect a USB? Could it be, even though my USB stick works, the BMW software can't pick it up maybe? Thanks in advance. |
08-18-2021, 11:43 AM | #42 | |
Rep 4
eddiehaug748.50 |
08-21-2021, 04:10 AM | #43 |
Rep 190
Okay, so next drama update.
I managed to sort out my HDD issues and formatted to exFAT to receive this file. I downloaded it using the bmw downloader and it, again, left just one file. I cant understand what the problem is or how to overcome it :/ |
08-21-2021, 06:01 AM | #44 |
Rep 190
Okay! I had a think about it and opened the one file with Winrar... It seems like all the files are contained within as described, so I'm now copying to the USB. I should be good to go!
