08-14-2021, 10:29 AM | #1 |
Rep 429
Options for lowering m340i xdrive w/ Adaptive Susp?
I currently have a m340i RWD with Dinan springs. The height is perfect, ride and handling are great.
I'll be getting a 2021 m340i xdrive with Adaptive Susp. Are there any options for lowering springs? Dinan doesn't offer them for that spec |
08-15-2021, 11:31 AM | #2 |
Rep 88
You can go with Cobra, I have them on my M440 xdrive and they are great. Probably ride a little lower than the Dinan, but I think they are a little higher than the H&R. Price point is pretty comparable too.
08-15-2021, 08:57 PM | #3 | |
Rep 429
Do you have Adaptive Susp? If so how did the Cobra affect the the ride and handling? |
08-17-2021, 03:05 PM | #4 |
Rep 429
So far, I've found:
H&R - 1.3 inch / 33 mm drop at around $250 Cobra Suspensions - 1.18 inch / 30 mm drop at around $410 AC Schnitzer - about 1 inch / about 25 mm drop at $720 Thought others may want this information, if they don't know it already. As well, if there are any other suggestions, please post. Thanks |
08-17-2021, 05:16 PM | #5 |
Rep 88
I do have the adaptive suspension, overall no complaints on the ride. Its maybe a little firmer in comfort, but not so much so that I find it a problem for my 34+ mile each way commute that typically involves a mix of every quality of road surface imaginable. Everything firms up nicely in sport and a good fast curve feels pretty flat.
08-17-2021, 05:19 PM | #6 | |
Rep 88
08-17-2021, 06:03 PM | #7 | |
Rep 429
I looked at your pictures, in your thread, and am wondering how much the Cobra springs lowered your 440i. If you look at your car, from the side, can you see the top of your tire tread? Wondering how much space is between the top of the outer tread and bottom of the fender. Thanks again. |
08-17-2021, 06:49 PM | #8 | |
Rep 25
Thank you
amrh296.50 |
08-18-2021, 03:48 PM | #9 | |
Rep 88
08-29-2023, 03:25 PM | #10 | |
Rep 8
They are disabling adaptive damper function, and was wondering how it works for cobra |
