09-19-2021, 11:22 AM | #25 |
Rep 151
Yep. That's one of the reasons I went with a 330i M Sport. The lower weight and slightly better balance make the car a little more nimble than it's 340i sibling. At the end of the day it's always easier to add power than to subtract weight.
g20beam474.50 |
09-19-2021, 01:37 PM | #26 |
Cailín gan eagla.
70820
Rep 1,004
09-19-2021, 03:33 PM | #29 |
Rep 1,037
Your car looks great!
Can you share some specifics about the peelable paint? Who makes it, and are you happy with the smoothness/gloss of the finish? Is it easy to clean? |
floating.spirit1017.00 |
09-19-2021, 08:40 PM | #35 | |
Rep 510
After all the mixing, they spray it with regular spray gun, leave it overnight and magically it becomes a sticker. The finishing results is like a regular paint. Flawless. Smooth like butter. Shiny just like real paint. This paint will last a long time as long as you don’t try to peel it off. In fact its so strong that you do need their special chemical to peel it off. You can’t just peel it off with your bare hand. Treat the wheels like ordinary wheels. I used regular soap with wash mitt. The PPS chemical is 100 % safe for the original paint. Very expensive though. But you get what you pay for. Worth every penny. Last edited by vortechvr6; 09-20-2021 at 01:39 AM.. |
09-19-2021, 08:53 PM | #36 |
Rep 510
It rides awesome! The coolest thing about KW V3 is the double rebound adjustments. Low and high speed adjustment. I set it up softer setting for the low speed so that its still soft enough when you hit bumps/pot holes. And I set the high speed adjustment a bit stiffer so that the car has less body roll and less bouncy.
09-20-2021, 10:59 AM | #43 |
Rep 510
My car is not 320i. It is in fact 330i With full option M Sport. It is the highest trim that you can get here. Sadly, we don’t have the M340i. 330i M sport is the highest trim that you can buy here. That’s why I bought it. Anyway, if I could somehow purchased M340i over here, I still going to install the same aftermarket parts like I have now...
