BIMMERPOST Universal Forums Off-Topic Discussions Board (trying to) improve my game - steaky steaky steaky !
      09-06-2021, 11:41 PM   #23
BMW F22
BMW F22's Avatar
Drives: ///M235i
OP: you learn over time. Hard to gauge exactly because we don’t know how thick your steak is and how hot your oven and stoves get. Overall, you need a decent thickness to the steak. Those thing slices will over cook in a minute. The thicker the steak, the longer you might want to sear and leave it in oven for cooking (but not by much).
Originally Posted by P1 View Post
People really, really overthink making steaks.
Made my mouth water and I had a lot of steak this week.
nazali1305.50
P111572.00
JJ 911SC22393.00
      09-07-2021, 12:25 AM   #24
c1pher
Primo Generalissimo
c1pher's Avatar
Drives: All of them
Originally Posted by DETRoadster View Post
#1 tip, you need to salt your steak on both sides an hour before cooking. This allows time for the salt to be drawn into the meat and absorbed. It greatly improves the flavor.
It also acts as a tenderizer. You should salt at least an hour before you grill to allow that process to occur. I usually do a quick minute on each side and then flip a couple more times before getting to temperature…depending on thickness. I little pat of kerigold butter on top (love the garlic kind) is nice too.
About the amount of salt….I find most videos on the topic way over salt. If you use the Sea salt, it’s not refined and has larger flakes, you’ll end up using much less of it.
Also to cut down on smoke, I have switched to avocado oil. I only use sea salt, black pepper, garlic and sometimes a little paprika.
DETRoadster11462.50
DocL1930.00
nazali1305.50
      09-07-2021, 08:26 AM   #25
DETRoadster
Space Force - 4 Star General
DETRoadster's Avatar
11463
Drives: M2 MG 6MT / Moto Guzzi V7
Agreed on the avocado oil. It's great! Would be a good move for the OP who is cooking indoors.
      09-07-2021, 09:08 AM   #26
Alfisti
Drives: 2008 Saab 9-3 Combi
Nothing beats a rib eye. My method is super simple, I take the cut out an hr beforehand so it warms to room temp, and i season with barbarians steak seasoning. It is the best steak seasoning as it doesn't really have a flavour so to speak, well it does but it's more about extracting the taste of the meat.
heat grill to 600 degrees, oil it up and throw steaks on. Turn them once only, time depends on who i am cooking for and thickness of the cut.
Eat.
nazali1305.50
      09-07-2021, 09:39 AM   #27
TheWatchGuy
TheWatchGuy's Avatar
3905
Drives: 335xi
ive got 2 methods i use for steak.
1st - Pull steak out and season and let sit at room temp for ~30 minutes. Smoke at 225 to ~115 with occasional basting with butter to keep it juicy. Pull off, coat in Mayo, season (usually Himalayan Salt and crushed pepper) and sear in cast iron. Rest for ~10 minutes. (if i dont want to do it inside on the cast iron, I'll either put the cast iron on the gas grill, or forgo the cast iron and sear on the gas grill at 500-600 degrees while basting with butter.)
2nd for when i dont want to spend a ton of time cooking - Coat in Mayo and seasoning and let sit for ~30 minutes in room temp. Sear in hot cast iron for 1-2 minutes a side. Baste with garlic butter with rosemary, thyme and full scallions for ~7 minutes or until its at a medium rare. Rest for ~10 minutes
The smoke/reverse sear method is my favorite and gets me the right temp about 95% of the time, while retaining a lot of the juices.
And while Mayo searing may seem weird to a lot of people, you dont taste the mayo at all and it gives you a great crust on the steak since its basically egg and oil. I used to sear in an Avocado oil, and while its still good, the Mayo Sear steps it up a notch.
Been thinking of picking up a sous vide for reverse searing as well so i dont have to fire up the smoker. You could probably do the same in an oven if you dont have a smoker. Just have to be careful not to dry it out.
@drunkcowatches on ig
Am I a watch guy, or do i watch guys?
nazali1305.50
      09-07-2021, 09:44 AM   #28
Merlin_83
Merlin
Merlin_83's Avatar
Drives: 2012 BMW M3 6MT w/ZCP
2012 BMW M3 ZCP  [0.00]
2008 BMW 335i  [0.00]
2008 BMW 335xi  [0.00]
Although partly on topic, I have it also down to a repeatable science on my Traeger grill.
This is for Tri-Tip - kind of unique to the West Coast of USA, was started in Santa Maria, CA.
Take steak (Tri-Tip) out and leave on countertop for 45-60 minutes, use dry rub (below) not many know of this rub - but I have tested probably 20+ rubs, either made myself or store bought. This rub https://www.oakridgebbq.com/product/...teakhouse-rub/ - this will change your steak results both pan seared on on the grill.
Anyway, steak is rub generously with Carne Crosta, left to sit for 45-60 min. - start the Traeger at 165 degrees and smoke the Tri-Tip for 50 minutes, remove and wrap well with aluminum foil, set aside. Crank Traeger up to 500 degrees, then place on grill for 4-5 minutes on each side - total steak house results magnificent ! *newer Traeger can actually get to 500 degrees, older ones not so much. This is our second Traeger, we grill 15-18 times per month.
Cheers,
Merlin
2012 E92 M3 ZCP | 2008 E90 335xi | 2008 E90 335i |
nazali1305.50
      09-07-2021, 10:24 AM   #29
Manny01
Drives: 2021 BMW M2
There's ZERO benefit to letting a steak come to room temperature before cooking. If it's thawed, it's ready to cook.
https://www.seriouseats.com/old-wive...-cooking-steak
https://amazingribs.com/technique-an...-to-room-temp/
https://www.mashed.com/221699/the-co...ctually-false/
https://www.smokedbbqsource.com/8-my...eed-to-ignore/
nazali1305.50
      09-07-2021, 01:56 PM   #30
BMW F22
BMW F22's Avatar
Drives: ///M235i
Here's another one. This is lunch for today.
nazali1305.50
JJ 911SC22393.00
      09-07-2021, 03:56 PM   #31
TheWatchGuy
3905
Drives: 335xi
Originally Posted by Manny01 View Post
the letting it rest at room temp is more for letting the seasoning penetrate into the meat and get the surface temps of the meat higher for a better, more even sear. also allows the outside of the steak to dry off some for a better sear. it has nothing to do with the internal temps.
is it necessary, probably not. but i tend to get better sears when i let it sit out.
nazali1305.50
      09-07-2021, 08:23 PM   #32
ashtaron14
ashtaron14's Avatar
Hong Kong
1123
Drives: G80 M3
I think it depends where you live.
HK is like 78% humidity and 30 degrees Celsius.
I don't think it'll be healthy to leave the steak out.
      09-07-2021, 08:49 PM   #33
BMW F22
BMW F22's Avatar
Drives: ///M235i
This. Leaving anything out for more than 20-30 mins will cause bacteria to grow. Exceptions are: the item was frozen and/or you live in a cold climate.
      09-07-2021, 09:55 PM   #34
Gregrobin
Drives: 2008 E93 335i
Originally Posted by 6oclockshadow View Post
When I cook steak indoors, I sear both sides on very high heat in a cast iron skillet for 1.5 to 2 minutes per side, then into a very hot oven (450f-500f) for 5 minutes. Perfect medium rare.
THIS! We do this with our bone in pork chops as well. And we always, always chose a filet.
VRSF Performance Intake Kit / XS Power Charge Pipe V2 / ARM 5" Intercooler FMIC / MHD Stage 2 V10 / FTP N54 PCV Valve / VRSF 3" Catless Downpipes / xHP Stage 1
      09-08-2021, 12:25 PM   #35
nazali
nazali's Avatar
Drives: 230 2020 vert F23
ok,
so got some kosher
bought a cast iron heavy bottom skillet
as thicker sirloin as I could get from the in-house butcher
they said I can request a thicker cut if I want, only when the butcher is in,
something like 7-3pm
I'll try and take some pics
      09-08-2021, 01:14 PM   #36
UncleWede
UncleWede's Avatar
Don't go throwing a good steak into a brand new cast iron pan!!! You have to season that thing well before adding good meat.
DocL1930.00
upstatedoc7559.50
nazali1305.50
Gregrobin578.00
Dpc2u11503.00
      09-08-2021, 01:24 PM   #37
dreamingat30fps
Drives: Miata, Cayenne, Model 3, F350
I'm no steak cooking expert. However my biggest issue for me was getting it a good medium rare and also getting a nice crust/sear on it. I always ended up over cooking. Using the reverse sear method has totally helped me with that. I still use a meat thermometer to check temp and I take it out at around 130 and sear it it on a 500-600 degree cast iron skillet.
NY strip and ribeye are my cuts of choice. I've only done 1 trip tip but I liked it a lot also for a pretty damn lean cut.
nazali1305.50
RJD851128.00
      09-10-2021, 09:28 AM   #38
nazali
nazali's Avatar
ok guy's, a partial success. Pls see pics, now, the steak was just shy under an inch thick, I pulled it off at 125 very pink inside, but very juicy and NOT chewy, does this look RARE ? There was no blood on cutting, I think the heat was too much as the outside looked very "burnt" but the taste of the steak really came through, cut like butter, the gravy let me down, very bland, mainly because there was no real juice ? Had with boiled pot's
enjoy the pics and of course fo let me know your thoughts,
      09-10-2021, 09:30 AM   #39
nazali
nazali's Avatar
first we have the steaky
      09-10-2021, 09:31 AM   #40
nazali
nazali's Avatar
I didnt use my new cast iron, but a new skillet, the container is my home made garlic butter with herbs
      09-10-2021, 09:33 AM   #41
nazali
nazali's Avatar
gravy let me down, but there was hardly in jus in the pan, the mix you see was garlic, onion powder and worchester sauce
      09-10-2021, 09:37 AM   #42
BMW F22
BMW F22's Avatar
Drives: ///M235i
Progress! If it’s pink inside then you haven’t cooked it at low heat long enough to cook the inside. You could heat up oil or butter and baste it, or put it in the oven at 350-375 for a few minutes. That looks like a good sear so good job on that.
      09-10-2021, 09:40 AM   #43
nazali
nazali's Avatar
here we go gravy made
      09-10-2021, 09:41 AM   #44
nazali
nazali's Avatar
rested and cut, temp was 125
