Technical Topics B58 6-Cylinder Turbo Engine / Drivetrain / Exhaust Modifications Spark plug help
      09-19-2021, 04:16 AM   #1
S58King
S58King's Avatar
148
Drives: 2022 G80 M3 CX
Spark plug help
Would it be okay to run .022 gapped one step colder spark plugs if I’m running a jb4 with fbo and not a real tune? Feedback is appreciated
      09-19-2021, 10:42 AM   #2
tarrant64
Drives: M340i
One of those things that will have to be tried out to see if the experience is worth it for you.
Generally - larger the gap the better MPG and efficiency. That said, once you start getting into higher boost demands - which the JB4 would count for - you want a tighter gap.
Shouldn't hurt anything. If you start feeling what you think is a misfire or something re-check your gaps or go back to stock gap.
      09-19-2021, 05:59 PM   #3
S58King
S58King's Avatar
148
Thank you so much for the response brother
      09-20-2021, 08:25 AM   #4
kuzdu
Drives: 21 M240i
So I got jb4 running map 5 and i change my plugs to ngk and gapped .022, made the world of difference very smooth power now.
      09-20-2021, 02:55 PM   #5
S58King
S58King's Avatar
148
Ugh great to hear brother I love when fellow g20s comment for the situation from their point of view I appreciate it
      09-20-2021, 04:16 PM   #6
kuzdu
Drives: 21 M240i
I actually have an M240, runs like a beast omg lol but the plugs shouldn't harm your engine. gap them all to .022 and give map 5 a run with some E40 blend and you let me know if you have any neck pains after that from the torque lol
      09-21-2021, 02:39 AM   #7
S58King
S58King's Avatar
148
You don’t think running more E with stock pumps would damage anything?
      09-21-2021, 06:55 AM   #8
kuzdu
Drives: 21 M240i
i upgraded my pump to the one you guys have on the 340 and supra so im good to go
      09-21-2021, 11:39 AM   #9
S58King
S58King's Avatar
148
Wait so would it be fine to run e40 in my g20?
      09-22-2021, 07:07 AM   #10
kuzdu
Drives: 21 M240i
as long as your tune supports it. weather you flash with an E40+ map or on JB4 yup it can handle it. so far all my logs have been clean, im hitting around 22-23 lbs of boost at wot it's killer
      09-25-2021, 06:47 PM   #11
Antec800
Drives: 340i x drive
If your on stock tune putting some e85 with 93-94 won’t benefit anything it will with 91 though in hotter weather benefit in timing. If you have a flash or jb4 e85 is safe up to e40 and beneficial
