09-26-2021, 08:33 PM | #1 |
Rep 67
Pressure washer
I took delivery of my M440i this week and am driving it back from PCD.
I used to take my previous car through the car wash but want to wash this car at home. I was wondering if anyone had recommendations when it comes to pressure washers. Any other tips for at home washing are welcome. |
09-29-2021, 02:35 AM | #2 |
Rep 1,667
SunJoe SPX3000 seems to be the most common "bang for buck" for home washing.
I'm ordering one of those and then a TriNova foam cannon ($35 on Amazon). I have Microfiber Madness mitts and drying towels, still shopping for bucket + grit guard. I plan on probably one good wash per month / quarter and foam spray on / spray off / dry quick wash about every other week / once a month. Depends on how I feel in between. Might be excessive. But I've put 8k miles on it since April, so....
Ego is the anesthesia that deadens the pain of stupidity.
The single biggest problem in communication is the illusion that it has taken place. Wheel horsepower is just crank horsepower after taxes. IG: EmFore_650 |
fxcw8544.00 |
09-29-2021, 11:28 PM | #3 | |
Rep 185
fxcw8544.00 |
09-30-2021, 10:12 AM | #4 |
Rep 1,053
This is probably a stupid question....but do you use the pressure washer on the car? I just assumed even the lowest setting would ruin car paint.
Current: 2021 340xi
Retired: 2018 330xi | 2016 340i 6MT | 2013 335i 6MT | 2011 328i 6MT (N52) | 2008 335xi (N54) |
09-30-2021, 01:14 PM | #5 |
Rep 1,667
That's partially why the SunJoe is so popular I think. It's on the lower end of medium power for pressure, quiet, with multiple tips to get the right spray. As long as you keep the tip at least 18" from the paint you should be fine from what I'm told. I have PPF + ceramic coating on mine and that's what my detailer said - 18-24" away from the paint and you're still fine, 12" is probably still ok but getting risky, anything closer and you may start peeling the PPF.
sfgator40.50 |
10-01-2021, 07:19 AM | #6 |
Rep 148
You might want to check out Obsessed Garage. Matt has tested dozens of different power washers (data available in a spreadsheet) from low end to commercial grade. About 1000 psi is a good target for washing a car. Matt drives BMWs and Porsches and his wash technique has been proven over many years on both coated and ppf cars.
10-01-2021, 11:15 PM | #8 |
Rep 2,699
Drives: 23 X5MC
I bought a Kranzel 1122 pressure washer from Matt at O.G. I love it, it is pricey though.
10-26-2021, 04:28 PM | #9 |
Rep 122
I saw a guy on YouTube take his car to a carwash, only to use their wand. He had his own buckets and wash mitts in the trunk.. Pretty smart if you ask me and I don't know why I never thought of it.
10-26-2021, 11:13 PM | #10 | |
1942
Rep 3,521
PS - You can't do that at crowded coin washes. Most won't let you use your own bucket and soap either. I'm lucky to live in a small town with many coin washes that have hardly any patrons visiting. Even then, I usually go late in the evening or early morning when it's abandoned.
10-27-2021, 08:17 AM | #11 | |
Rep 122
VipinLJ1941.50 |
10-29-2021, 10:30 AM | #12 |
Rep 395
I find it interesting that there are places with coin-operated self-washes that actually monitor your use of a bucket and soap. Every one I’ve been to was completely unmonitored, and you were lucky if they even had a working change machine or credit card swipe.
10-30-2021, 08:06 PM | #13 | |
936
Rep 4,326
Drives: M340
There really is nothing better than Kranzle out there but then OP sounds like a newbie and this might be a little too much for what he is looking for.
themnmd1691.00 |
11-22-2021, 03:28 PM | #14 |
Rep 114
Electric and gas pressure washers are fine--honestly anything over 2000 PSI. My only advice is to steer clear around headlights and tailights and really anywhere there is exterior lighting as you don't want to break seals with pressure. The real fun is the foam cannon.
12-11-2021, 02:14 PM | #15 |
Rep 751
I love my Sun joe SPX3001 and cheap foam cannon (both from Amazon on sale a while back). I stick to Megiuars mid level products for wash, correction, and protection. I'm not a crazy OCD detailer like you see online, but these products work great for me.
I also picked up a Griot's DA polisher and some lake country foam pads. All have been great for a novice like me and have had great results. |
12-11-2021, 06:52 PM | #16 |
Rep 404
Sunjoe sxp3000, use the 40degree tip. You can spray as close as 12" away from the surface without harming anything. You'll want to look into getting a short gun for it and replacing the hose plus adding QDs. The standard hose and gun just suck to use for washing. Get a decent quality foam cannon (30-40$), find a quality soap, and use microfiber mitts and pads. Incredipads from Microfiber Madness are good but a little pricey. The Rag Company has their cyclone mitts and pads that are really good also and a bit more affordable. I use the multi pad method instead of messing with grit guards. You would have a mixture of 5 pads, and mitts. Once you've washed a panel or two then throw it in a separate bucket and grab another.
Alternatively, Obsessed Garage has curated packages available. |
sfgator40.50 |
