10-18-2021, 12:51 PM | #1 |
Rep 166
Minimum spacer size for rear?
Hi guys,
Does anyone know if there's a minimum spacer size for the rears on our g20's? I know that when I had my f30, 12mm was the smallest size you could run for the rears. Thanks in advance! |
10-18-2021, 09:59 PM | #2 |
Rep 446
Don't you mean maximum size? Running small spacers would not create any issues. It's the larger size spacers that may cause issues depending on the size of your tires/rims/offset and if you have lowering springs. I've seen 10mm through 20mm spacers offered for the G20. Keep in mind, a 10mm spacer is less than half an inch. I'm running 15mm spacers on all 4 of my stock 19-inch rims with 225/40/19 tires (square set-up) and they look perfect.
2021 M340i xDrive Sedan | Portimao Blue Metallic | Cognac Vernasca Leather | Maple Matte Finish Wood Trim | 19-Inch 792M Wheels | Red Brake Calipers | Premium Package | Driving Assistance Package | Adaptive M Suspension | Harman/Kardon Surround Sound | Painted Rear Spoiler (Z50)
2014 335i xDrive Sedan | M-Sport | Estoril Blue Metallic | Venetian Beige Leather (Sold) |
10-18-2021, 11:16 PM | #3 | |
Rep 166
Hey thanks for your reply I actually did mean minimum. Like I stated, for some reason with the f30, you could only use 12mm and up for the rears. Anything under 12mm wouldn't work. So I was wondering if it's the same for this chassis. I'm not on stock wheels, I'm actually running 19x9.5 with 265/30 tires in the rear so I'd want to experiment with smaller sized spacers (sizes 10mm and under) |
10-18-2021, 11:18 PM | #4 | |
Rep 146
10-19-2021, 06:00 AM | #5 |
Rep 446
I can take pictures. The spacers come with new extended lugs.
10-19-2021, 10:58 AM | #6 | |
Rep 2,180
08-18-2022, 02:31 PM | #7 | |
Rep 153
Thanks for the response! |
08-19-2022, 09:34 PM | #8 | |
Rep 446
In terms of voiding the warranty, you may want to search this forum, but I am not familiar with any situations. If you were to have an issue with your steering, front suspension or front wheels, a dealer may try to place the blame on the spacers. Just to be on the safe side, my advice would be to remove the spacers if you plan to take your vehicle to the dealer for service related to an issue with your front wheels, steering or front suspension.
11-03-2022, 01:29 PM | #9 |
Rep 140
Hi guys, I tried searching the forum but didn't have much luck finding the answer, this is the most recent and closest thread related to my question. I hope OP don't mind me posting here.
I have a set of aftermarket wheels purchased from a friend of mine and I am afraid of the risk of the lug bolts being too long, damaging the parking brake. May I kindly ask if anyone know what is the minimum safe length extending from the back of the wheel for our cars are and what is the maximum safe length (before it damages the parking brake?). What about for the front, length shouldn't be an issue right, there won't be risk of damaging the ABS sensor? Thanks! |
