Technical Topics DIYs and Coding Discussions G20 laser headlight and hud retro fit
      07-11-2020, 06:36 PM   #1
Mikeowen03
Drives: Bmw 330e g20
I have just purchased another bmw g20 from an insurance company which has front end damage, it doesn't have heads up display altho I have the hud dashboard and hud unit already, also it has led headlights as standard theses are damaged but I have a set of laser headlight I would like to put in, can somebody help with coding for both hud and laser headlight any help would be appreciated
Thanks in advance
      08-11-2020, 03:12 PM   #2
Mikeowen03
does anybody know on how i code theses used pair of laser headlights instead of led lights
      08-12-2020, 03:36 AM   #3
Rastlein
Drives: BMW 320i
I'm interested. I plan to replace my led standard headlights with lasers in the future. Where did you buy the laser headlights?
      08-20-2020, 05:18 PM   #4
Mikeowen03
Already had a set of laser lights I fitted them last week and had them coded in already
      08-21-2020, 04:22 AM   #5
Rastlein
Drives: BMW 320i
Can you explain the installation and coding process and put some photos of the car before and after?
Thank you!
      08-26-2020, 04:09 PM   #6
Mikeowen03
Instalation direct replacement no wireing need as led headlights and laser headlight share the same plug and pin locations for wires, you will also need to place the squib to 1 that has both BC button and auto high beem assist button on the lfleft indicator stalk, I did not code the laser headlights in I had somebody remotely code this from Lithuania for £50,
Have also fitted HUD and wireless phone charging,
2019 bmw 330e, M340i carbon M Performance conversion
      09-08-2020, 04:23 PM   #7
NFB
Drives: BMW 330i
What was needed for the HUD to be fitted and coded?
      09-08-2020, 07:34 PM   #8
purpl3ish
purpl3ish's Avatar
Drives: 2023 G80 Velvet Orchid M3
we can swap for my painted ones when my lease is over!
2020 G20 Twilight Purple M340i xDrive,
2017 F80 30 Jahre, 2011 E92 335i xDrive///M3, 2012 E93 ///M3 -- Retired
      01-25-2021, 05:54 AM   #9
vsterian
Drives: BMW 320xd G20
Mikeowen03
I'm curious about one thing, I assume that your G20 came without HBA, right?
How did you manage this topic in regards with the Laser Retrofit?
I have also a 320xd G20 with standard led and no HBA ( no splited BC/HBA handle on the left side of the steering wheel).
Can Laser lights can be coded without that handle and be fully functional?
Thanks,
Vlad
      03-08-2021, 11:13 AM   #10
Eyeball
Eyeball
Eyeball's Avatar
32
Drives: BMW G20 330i MSport
Thank you!
Hi there I am considering swapping my led lights to laser. Can I just swap the lights and use electrics from my leds or do I need modules etc ?
Why look back, that?s done !!!
      03-15-2021, 09:35 AM   #11
kamer7
Drives: G21 330i, G01 25d
n
What about upgrading basic LED headlights? There are 3 versions: base, extended and Laser lights, is going to Lasers from the bottom version without High Beam Assist any more difficult than from middle one?
