Technical Topics DIYs and Coding Discussions Help with bummer code not connecting to BDC
      09-06-2020, 04:16 PM   #1
Cbullard3895
Drives: 2019 330i
I'm hoping someone can help, I have a 2019 330. Downloaded the bimmercode app, joined the beta, purchase full version and have the OBDlink LX adapter for android devices.
When I try to code sport + in bummer code I click on BDC and the app takes its time to load and then I get an error that it cannot access code data. Other parts of bimmercode work such as the instrument cluster but not BDC.
Any suggestions??
      09-06-2020, 05:18 PM   #2
chenry
Drives: M340 & Many BMWs Prior
Not sure is this is applicable to your situation but I will share that when using bimmercode on my 2020 M340 and connecting with a wireless adapter I could not gain access to all the control units. I switched to a wired adaptor (for me with an iphone it was lightning to OBD) and all control units were then accessible.
      09-06-2020, 06:28 PM   #3
greekcs
greekcs's Avatar
Drives: 2020 M340i xDrive
I've had the same issue lately with Bimmercode. BDC loads for a while and then errors out.
2015 09/14 Alpine White on Red 435i xDrive MPPK - Expensive black vinyl with special lettering. SOLD
2020 12/19 Mineral Gray Metallic on Black Vinyl interior M340i xDrive
      09-07-2020, 05:37 AM   #4
Joedeejay
Drives: BMW G20
BDC module needs a fast adapter, sounds like it's taking too long to read the module and timing out and giving the error. No issue for mine using wired enet adapter on android
      09-07-2020, 08:29 AM   #5
Saunders17283
Saunders17283's Avatar
Drives: 2020 M850xi Gran Coupe
OBD to lightning is the way to go if you have iPhone. It's super fast and very stable.
I use this combo & everything works flawlessly.
ENBIA RJ45 Ethernet LAN Network Adapter for Phone Pad, Phone Ethernet Adapter, 3.3ft/1m Cable, 10/100Mbps High Speed,Plug and Play Enbia (Silver) https://www.amazon.com/dp/B07SYH7PMW..._psJvFbBGGBBT6
OHP ENET OBD to Ethernet E-SYS Cable | RJ45 to 16 Pin Diagnostic CAT5e OBD2 for Coding F-Series, 1 Series, 3 Series, 5 Series, GT, X3 & G-Series | 5 F https://www.amazon.com/dp/B07V3C47YD..._fVWpY5egCApRp
Current Ride
Previous Rides
2019 X7 / 2018 X5 / 2012 X5 / 2014 750xi / 2011 750Lxi / 2008 335xi
      09-09-2020, 02:41 AM   #6
fdopperen
Netherlands
Drives: 3serie / G21 / 330i
i order yesterday a adpater for android usb c to rj45
and it works great with bimmercode and enet cable
its possible to read every module what bimmercode see
only cant see how to active lane change assist
      09-09-2020, 11:19 PM   #7
X32G20
Drives: G20
I had trouble accessing modules when I first got my adaptor. Try updating the firmware of your OBD adaptor. Once i updated mine, everything worked as it should have.
Copyright ©2000 - 2020, vBulletin Solutions Inc.
