Technical Topics DIYs and Coding Discussions Coding boot lid close?
      09-09-2020, 11:29 PM   #1
X32G20
Drives: G20
I'm not sure if I have the power tailgate, but the trunk does open with the trunk button from the driver's side and it does open when I wave my foot under the trunk from outside the car. Is it possible to code for the trunk to close from the driver's side or from the key fob, and is it possible via bimmercode?
      09-10-2020, 12:19 AM   #2
VipinLJ
VipinLJ's Avatar
Drives: Ď20 330i,Ď16 X3,Ď18 SQ5,Ď17 A7
If you have a powered boot lid, there will be a button on the inside liner to close the lid (like in most SUVs). If you donít have the button, you donít have power tailgate.
It *might* be possible to code the trunk lid to close ONLY if you have a powered tailgate.
2020 BMW 330i xDrive
2018 Audi SQ5 Prestige
2017 Audi A7 Prestige
      09-10-2020, 03:21 AM   #3
G20NZ
Drives: 2010 135i
I've got the powered tailgate and it opens and closes from both the key fob and inside the car from factory. If you don't have the powered tailgate option it will kick open but not close as there's no motor installed. Hope that makes sense.
      09-10-2020, 03:39 AM   #4
rickkap
Drives: 320d XDrive M Sport (G20)
Usually if you have the button on the driver's side you will have a powered tailgate. If you pull this switch, with the boot (trunk) open, and hold it it should close it. Also there will be a switch on the inside of the trunk to also close it.
      09-10-2020, 12:15 PM   #5
mikeyb74
Drives: G20 330ix M Sport
I went thru bimmercode looking for the option to code close trunk lid with remote or with the cabin button. I didn't found anything that would allow me to code to close feature. I also looked into retrofitting the power open and close feature on mine. Not worth it for almost $2K for just the genuine BMW parts. I did find this on alibaba.
https://www.alibaba.com/product-deta...d75f69d4cCT0f6
      09-10-2020, 12:49 PM   #6
howiegu
Member
howiegu's Avatar
Drives: 16' 340xi Msport
If you have power lid, you can use BimmerCode to code the functions you want. [IMG][/IMG]
      09-10-2020, 02:48 PM   #7
mikeyb74
My F48 X1 had these listed to code the power tailgate. I actually miss this feature on my G20.
      09-11-2020, 11:02 AM   #8
X32G20
Drives: G20
Thank you all. I have confirmed that while I do have the button on the driver's side door (that lifts up and pushes down) it only opens, as it is not motorized.
Copyright ©2000 - 2020, vBulletin Solutions Inc.
