09-15-2020, 04:36 PM | #1 |
Freude am Fahren
474
Rep 362
Drives: G26 i4 M50, F11 M550d, E70 X5
Garage List 2011 BMW E70 X5 xDr ... [0.00]
2015 BMW F11 M550d ... [0.00] 2024 BMW G26 i4 M50 ... [0.00] 2009 730dA [10.00] |
Successfully retrofitted steering column stalks that returns to 0-position/center
I'm one of those people who hates the mechanical turn signal and wiper levers/handles BMW introduced in connection with the G30 5 series and on later models. So much so that I actually considered not buying a BMW again.
They feel cheap and they make a noisy plastic sound. In addition, it is annoying that the auto on the rain sensor is gone, so you can not take an extra swipe without turning off the rain sensor and have to manually pull the lever/handle up in auto mode again. It is with great pleasure to say that it is possible to retrofit the old levers that return to the 0-position / center position, illustrated by a G20 3-series. The lesson for BMW must be: if it is not broken, do not fix it! We hate the mechanical column stalks. So, here it is!
OEM+ customization is the way to go!
09-15-2020, 05:24 PM | #2 |
1942
Rep 3,521
Which car did you get the old stalks from? F30?
09-15-2020, 05:32 PM | #3 |
Rep 2,499
I completely disagree with you and this is just my opinion. I'm not saying I'm right and you're wrong.
The tactile feedback you get from discrete positioning for the wipers and turn signal are valuable tools. They give you a definite status on the turn signal or wipers. I use my turn signal religiously and I find cancelling it is the biggest pain in the butt with the older centering style stalk. If I accidentally hit the signal stalk meaning to do a full turn signal but accidentally hit the 3 flasher and I try to cancel it when I complete a longer lane change, I will sometimes activate the opposite turn signal. Doesn't happen often, but it's annoying. I also like being able to shut off the wipers immediately up an down to the speed I want instead of going through them sequentially. Also, American cars get auto wipers and that doesn't really have anything to do with the stalks. Like you said, if it ain't broke, don't fix it. I find the traditional discrete position stalks much more intuitive and error free. No one else really uses the re-centering system that BMW used for so many years and I'm glad BMW finally went back to the correct way to do it. This is definitely not an issue with cost (if anything the centering stalks probably costs less to manufacture) so I know the majority agree with me. In fact now that I think about it, I feel that the centering stalks might have been cost cutting. |
09-15-2020, 05:36 PM | #4 |
1942
Rep 3,521
I'm with you upsidedownfunnel. Hated it in my F25 and I had the exact same issues as you. I'm so glad they decided to go back to the traditional method with the new G series cars.
Jbrock22221.50 |
09-15-2020, 05:48 PM | #5 |
Freude am Fahren
474
Rep 362
They are from pre-03/2017 G11 7-series.
I would say you use them wrong if you accidentally turn the turn signals on in the other direction. If you blinking left, just tap to the left for cancelling - then you don't accidentally blink to the right side. To me, this handles feels so much modern and logic than the old style. Look at Tesla, they have startet to use this design on their Model 3, nobody complains about them. When they are "automatic" like this one, the stalks can have other functions as well (for example when autonomous driving mode - turn the signals to the left on, and the car will change lane and cancels the turn signal when the operation is done). This cant happen when the stalks are mechanical. And best off all - they don't sounds like plastic breaks. The return to the old style are definitely "cost cutting". I know someone loves them (like me) and someone hates them. So sad BMW didn't want the customer choose. I would easy pay 500-1000$ for this option when ordering a new car.
09-15-2020, 05:57 PM | #6 | |
1942
Rep 3,521
Again. Not saying I'm right and you're wrong. Just expressing MY opinion is all. Kudos to you for retrofitting the stalks though. It might help someone else do the same to their G20.
09-15-2020, 07:24 PM | #7 | |
Rep 2,499
Second it is cheaper to produce the centering style of stalks. Electrically they're nothing more than two momentary switches for up and down. For the detent style that you don't like, it requires additional hardware to distinguish all the different positions and the hardware to hold the stalks in place and the hardware required to reset the stalk after a turn is complete. So I can assure you it is cheaper to produce the centering style of stalks. Everything else is opinion so I'll leave that alone. |
09-16-2020, 05:19 AM | #9 | |
Freude am Fahren
474
Rep 362
Im also disagree that the touch-stalks are cheaper to produce. I have destroyed many of them, and the complex of the touch stalks are way more heavy than the mechanical stalks. That's my opinion, I accept yours.
Poochie9104.50 |
09-16-2020, 05:21 AM | #10 |
Freude am Fahren
474
Rep 362
F1x does not have this option available in its coding list.
09-26-2020, 07:43 AM | #11 | |
935
Rep 4,326
Drives: M340
BMW 1st introduced the concept in E9X cars and it drove us all crazy. There were pages of discussion. You would see cars driving on the road showing turn signals to the right, left and right again knowing the fact that poor driver is trying to cancel the darn thing. Of course over the years, I got used to how the system works. I am 50-50 on this discussion. I definitely like the new turn signal stalk better but would of preferred the old wiper switch. But it doesn't bother me that much to do something about it. OP, kudos to you for doing this..... It wouldn't of even crossed my mind as something that is possible to retrofit.
VipinLJ1941.50 |
09-28-2020, 05:54 PM | #12 |
Freude am Fahren
474
Rep 362
The worst thing with the new stalks (except of the plastic sound when you use them) are the lack of the auto button for the rain sensor. Its actually very annoying.
The next project will be retrofitting stalks in G31 5-series.
mlello16.50 |
09-29-2020, 12:45 PM | #13 |
Freude am Fahren
474
Rep 362
Everything works in an fully equipped BMW G20 3-series! Smooth and no plastic sounding stalks.
mlello16.50 |
01-15-2023, 11:57 AM | #14 |
Rep 25
Great work @BMW-ALPINA, I second your comment that the mechanical stalks are horrible.
BTW, did you successfully do the switch on your G31 (bigger challenge with its rear wiper, as AFAIK there are no G11)? |
02-21-2023, 11:33 AM | #16 |
Rep 3
Hello, I m from poland and i have a problem with indicator, when i press down it blinks 3 times but if i press full down it does't work. The left and right indicator it's the same.
02-21-2023, 11:38 AM | #18 |
Rep 3
06-05-2023, 03:16 PM | #19 |
Freude am Fahren
474
Rep 362
Sorry for late answer. I never managed to finish building a G31. Its correct that the rear wipers are the issue. For now, i think the best solution is to make a rear wiper delete.
06-05-2023, 03:17 PM | #20 |
Freude am Fahren
474
Rep 362
Did you went from "mechanical/rastend" stalks to "auto return stalks"? Your car is coded for "mechanical/rastend" stalks, so it need to be coded for the auto return stalks.
