09-18-2020, 06:13 AM | #1 |
Rep 383
Tyre Change xdrive
Been reading up on tyre change on a xdrive.
Should all 4 be changed at the same time as the rear are significantly more worn than front? Various people online say that different tread depth on front and rear can cause problems.
09-18-2020, 10:32 AM | #3 |
Grumpy Old Git
443
Rep 923
I’m pretty sure there is a difference in tyre thread depth limit for Xdrive . Check with your dealer...
Retired:
Andy3661121.50 |
09-18-2020, 10:59 AM | #4 | |
Rep 5,681
As an aside, experience with my F31 335d X-drive was that all four tyres tended to wear at pretty much the same rate so I'm surprised you're in a situation where the rears have worn much more quickly than the fronts. Too early to tell with my G21 but perhaps the X-drive set-up is different on the newer model with the tyre wear different as a consequence? Not if you have four relatively new tyres on the car but if they're all (say) half worn then potentially yes, if you get a puncture in one it might be wise to replace the full set on an X-Drive car. Of course this all assumes you're going to be keeping the car for a while - if you're not then you may be happy to take the risk mixing new and part-worn tyres on the basis any resultant drivetrain issue will be a problem for a subsequent owner..... |
Andy3661121.50 |
09-18-2020, 02:19 PM | #5 |
Rep 7,484
Yes problems do occur with the transfer box as it is sensitive to tread depth. If the tread is below 2.4 mm it make the box work harder. So all need to be above 2.4 mm in tread depth. Just change the ones that need to be done. Ideally match the tread pattern and brand on the same axle. However, if one is worn and the other is fine then it's not a big deal. I have had x drive with one tyre at 4 mm and one at 7 mm and it was fine but it was the same tread pattern and model.
Andy3661121.50 |
09-19-2020, 02:18 AM | #6 | |
Rep 2,242
