07-30-2019, 12:30 PM | #1 |
Rep 334
Is it possible to show the gear indicator on the HUD?
I have been playing around with manual shift and have been frustrated so far not knowing what gear I'm in unless I look at the instrument cluster. Does anyone know of a way to configure the HUD to make it show gear position? I almost feel like the HUD isn't living up to its potential in some instances, such as this.
07-30-2019, 12:44 PM | #2 |
BMW Client Advisor
3452
Rep 2,504
Maybe something they will reserve for the M3
Eagle Creek139.00 zamboni1130.50 |
07-30-2019, 03:44 PM | #3 |
Rep 101
I am not aware of a way to make the current gear appear in the HUD. I had a C6 Corvette with a HUD in which the current gear appeared, it is very useful. Maybe in a future OTA software update?
07-30-2019, 04:02 PM | #4 | |
Rep 334
Normally I would not care so much, but I feel like the transmission runs so smooth and almost feels insulated from the rest of the car. It's hard to determine sometimes what gear I'm in and whether or not I should downshift. I'll probably adapt. |
07-30-2019, 04:37 PM | #6 |
Part of the bimmer family!
139
Rep 293
Drives: BMWG20; BMW E90
He said he was using manual shift .
07-31-2019, 12:25 AM | #7 |
Rep 2,499
Is there a rev counter? It seems like that's really the only thing you need if you're selecting your gears manually. It doesn't really matter which specific gear you're in.
07-31-2019, 06:06 AM | #9 |
440i M-Performance
9
Rep 7
Doesn't it make a difference when you activate the sport display in the HUD? If you activate this, you see when to switch gear, not sure if you see the current gear also.
BMW 440i M-Performance
07-31-2019, 08:04 AM | #10 |
Rep 1,207
M cars has that. So you should be able to code it I think.
https://f30.bimmerpost.com/forums/sh...d.php?t=900019
11’ E92 ///M3
15’ F82 ///M4 18’ G30 540i ///Msport 21’ G20 ///M340i 24' i20 iX xDrive50 |
07-31-2019, 08:06 AM | #11 |
440i M-Performance
9
Rep 7
I have it also in my G20. You can choose to only see this when activating Sport mode or always.
07-31-2019, 05:37 PM | #12 |
Rep 334
The rev counter is not very clear... the problem is downshifting and staying in the power. As you slow down, it's not clear if and when you should downshift. It's probably just something I need to adapt to. In my old Lexus IS350, you just tap the downshift repeatedly until it won't let you downshift anymore and that means you're in the optimal gear to get back on the throttle.
07-31-2019, 05:48 PM | #13 | |
Rep 2,499
07-31-2019, 05:52 PM | #14 | |
Rep 259
hubbahubba8810.50 Seaford1147.50 |
07-31-2019, 07:07 PM | #15 | |
Rep 219
Drives: '19 G20 330i & '19 G01 X3
zamboni1130.50 |
07-31-2019, 08:26 PM | #16 |
Rep 334
Eagle Creek139.00 |
08-02-2019, 08:11 AM | #17 |
Rep 241
G20 330i HUD shift lights https://g20.bimmerpost.com/forums/sh....php?t=1635921
Previous: MY2013 328i xDrive Sport Line - Sapphire Black | MY2016 428i xDrive M-Sport - Mineral Grey BMW CCA #522637 use me as a referral for BMW CCA |
08-02-2019, 10:11 AM | #18 | |
Rep 547
Going from 7th to 3rd instantly while fully floored is insane.
Current: 2020 M340xi Previous: 2016 340xi |
08-02-2019, 02:52 PM | #19 | |
Rep 334
