2019+ BMW 3 AND 4-SERIES FORUMS (G2x Generation) General G20 Sedan / G22 Coupe / G26 Gran Coupe Discussions Windshield Washer Spray Defective?
      08-05-2019, 12:22 AM   #1
joepimentel
joepimentel's Avatar
76
Did BMW change how the windshield washer spray nozzles work on the G20? I noticed on my M340 that when I activate the washer it seems to release the liquid close to the wiper blade and then it gets wiped across the windshield as opposed to spraying on the windshield. Not sure if this is the new normal or if this indicates a clogged / defective nozzle.
      08-05-2019, 12:43 AM   #2
Laserdude
Laserdude's Avatar
Drives: 2007 Jet black e93 335
Yes on the g20 the windshield fluid now comes out of the wipers themselves
      08-05-2019, 01:25 AM   #3
Eagle Creek
Part of the bimmer family!
Eagle Creek's Avatar
Netherlands
139
Drives: BMWG20; BMW E90
2019 G20 330e  [0.00]
Yes, they changed it. Why would you presume this isn't working correctly? Instead of sprayers up or right under the bonnet they now are integrated in the wiper arms.
      08-05-2019, 09:16 AM   #4
JayPichardo
BMW Client Advisor
JayPichardo's Avatar
3452
2020 BMW M340i  [0.00]
They should have shown you that during delivery
jpichardo@tulley.com
      08-05-2019, 10:15 AM   #5
Eagle Creek
Netherlands
139
Why should they? There's lot of things changed. This isn't even something that I find that important since you only would need to know when having maintenance. And then u always have the owners manual..
      08-05-2019, 12:05 PM   #6
joepimentel
76
Because it's different than all other cars I've driven or owned, including my 2013 328 and my 2016 340. I believe traditionally most cars spray fluid across the windshield so when I saw fluid collecting at the base of the blade before it even wiped across the windshield I thought something might be wrong. I mean, it still doesn't spray from the blades... it just sorts of collects there and then gets wiped across.
Even though it's minor I agree. I'm sure I'm not the only person to be a bit confused by this. They went over most changes that are incorporated into the G20. Maybe this one was overlooked.
      08-05-2019, 12:29 PM   #7
Eagle Creek
Netherlands
139
Are you sure it doesn't spray from the arm itself? I cannot remember from my testdrive.
      08-05-2019, 12:45 PM   #8
joepimentel
76
Yeah, it seems to drizzle out and collect on the blade then gets wiped across. Seems a bit weird that's why I wonder if the sprayer(s) are clogged or defective.
      08-05-2019, 01:26 PM   #9
phillyd2
Drives: 2020 M340i XDrive
Then there is something wrong with yours. Check for clogs first.
      08-10-2019, 12:32 PM   #10
Eagle Creek
Netherlands
139
I'm standing next to a 330i right now, the nozzles are actually part of the arms and aren't under the bonnet anymore.
      02-23-2021, 09:02 PM   #11
RedKloud
RedKloud's Avatar
736
Drives: BMW i4 M50
I noticed this today on my car... and I can’t remember if the fluid was being sprayed previously. Can anyone confirm if this is normal behavior or not?
      02-23-2021, 09:25 PM   #12
TiMSport
Ukraine
12797
Drives: '21 M340i xDrive, '17 Audi S3
I wonder if that also prevents spray from hitting all the surrounding cars when using the windshield wiper fluid. I hate being behind another car that uses it and it gets sprayed all over YOUR car.
VetteGuy845.50
      02-23-2021, 11:26 PM   #13
VipinLJ
VipinLJ's Avatar
You're not alone. I noticed this recently too. I thought the nozzle was blocked since it doesn't seem to spray continuosly (but intermittently, if you get what I mean). Since quite a few of us noticed it, I assume it's normal?
That is mainly because those people haven't angled the spray nozzle properly. I've seen cars where the fluid squirts straight up into the air (and hardly any onto their windshield) and they have no idea why it's happening. Not many know that it can be adjusted easily.
2020 BMW 330i xDrive
2018 Audi SQ5 Prestige
2017 Audi A7 Prestige
      02-23-2021, 11:36 PM   #14
TriniJots
Driver
Drives: 2021 M340i
It's normal. It squirts a little pool at the bottom of the windshield then the wiper does the rest to spread it.
I am still not used to this new way. Not sure what the reasoning was behind the change.
2009 E92 335i
2012 E92 335is
2015 F30 435i
2018 CLA250
2021 G20 M340i (current)
RedKloud736.00
VipinLJ1941.50
      02-23-2021, 11:51 PM   #15
ovesund
Sweden
82
Drives: i4 eDrive40, i3 60Ah
I think the change is great, it saves a lot of washer fluid when driving on salted roads.
It's more effective as well, the window gets a lot cleaner. That's my experience at least. The only bad thing is that I can't use them to get a car to back off if it's too close for comfort
VetteGuy845.50
      02-23-2021, 11:57 PM   #16
VipinLJ
VipinLJ's Avatar
I agree. It is new and I can't seem to get used to it either.
Yup. Saves a lot of fluid. It also seems to be doing a good job. Only problem is, in my head, when I don't see a continuous squirt, it seems as though the nozzle is clogged and hence it isn't working effectively.
      02-24-2021, 12:23 AM   #17
TiMSport
Ukraine
12797
LOL
      05-25-2021, 10:48 AM   #18
nikhilarni
Drives: '18 GLC300 4Matic, '21 M340i x
I had the same question. I saw the nozzles were integrated into the wiper arm itself but the release of the washer fluid was too weak to remove any grime from the windshield itself.
I felt the nozzle was blocked. I'll try to poke it with a pin to see if anything is clogging it.
But you are right, the spray is very weak
      05-25-2021, 10:57 AM   #19
bavarianride
Drives: bimmer
Thanks for the heads up, I haven't tried the wiper at all, so this will be tested next.
      05-25-2021, 12:01 PM   #20
VetteGuy
Drives: Arctic Race Blue M440iX
The new spray works so much more efficiently, and you wont get flipped off by the cars next to or behind you for bathing them with your washer spray. I hate that!
      05-25-2021, 12:06 PM   #21
k4sh_90
k4sh_90's Avatar
Drives: 2020 BMW M340i xDrive
Window sticker says the nozzles are heated as well. I prefer the new design, loading up the wiper blade rather spraying the windshield. Spray is a bit too aggressive, so you end up getting washer fluid on the whole car and the guy next to you.
