2019+ BMW 3 AND 4-SERIES FORUMS (G2x Generation) General G20 Sedan / G22 Coupe / G26 Gran Coupe Discussions Remote start air conditioning levels
      08-05-2019, 06:41 PM   #1
mzdial
mzdial's Avatar
Drives: '19 G20 330i & '19 G01 X3
Is there a way to get the remote start air conditioning set to Max AC in the summer currently and maximum heat/seats/steering wheel in the upcoming winter?
I can't find documentation on it, and since I've had the car in the past two months, I've not used it often -- as it seems to default to how I left the car. Typically it's on auto, and fan speed at the lowest, or one above lowest. That usually means that it doesn't do much on a car that has been sitting outside in 90-95F days.
      08-06-2019, 04:48 AM   #2
Eagle Creek
Part of the bimmer family!
Eagle Creek's Avatar
Netherlands
139
Drives: BMWG20; BMW E90
2019 G20 330e  [0.00]
If it's on auto why it the fan speed fixed? I'd say the speed should vary based on how to match temperature.
      08-07-2019, 10:16 PM   #3
DallasExec
I'm not aware of any way to get the A/C to behave as you describe. Using remote start from the ConnectedDrive app, the A/C *does* turn on when the car starts, but it's not at the same intensity as if you were present in the car.
When you get in the car after remote start, iDrive asks you to depress the brake and start button, and once the car "starts" (is convinced you are really there) a noticeable change in the fan speed occurs and intensity of the A/C.
      08-08-2019, 12:06 AM   #4
xlover
Drives: 2023 X7 40i
Interesting... that's the opposite of the logic in the wife's grand Cherokee overland, upon remote start it goes max AC or heat if there is a large delta between vehicle temp and target temp, until the door is opened then it reverts to last setting
      08-08-2019, 09:13 AM   #5
JohnBarny
Drives: BMW F36 420d + G21 330i
Isn’t it just a ventilation function, no air con is used and it is a slow fan speed for 30mins to ventilate the car and nothing else?
      08-08-2019, 09:31 AM   #6
mzdial
mzdial's Avatar
I guess I'm just confused then. What's the point is of having remote start? This is the first BMW that I've owned with it, and every other vehicle I've had in our household (Jeep, Honda, Infiniti, etc.) will start the car and condition the environment.
I know there has always been (at least since iDrive started) the ventilation function, but it's somewhat pointless.
      08-08-2019, 03:58 PM   #7
SteveinArizona
Drives: BMW 530e
Unless you have a BMW PHEV. Then the precondition actually turns on the AC (or heat). After ten minutes of preconditioning, my 530e is perfectly cool after sitting in 110 degree Fahrenheit for five hours.
      08-09-2019, 03:38 AM   #8
Eagle Creek
Netherlands
139
That's because in the E edition both airco and heating are fully electrical because they need to be available even when the engine isn't running.
