Technical Topics DIYs and Coding Discussions Sailing/Coasting + Launch Control
      11-20-2020, 07:01 PM   #1
SeattleStefan
Drives: BMW 330i X-Drive
Hey guys,
Has anyone successfully coded costing on their g20? I followed the steps both within the headunit and gage cluster tabs on bimmercode and everything seems correct, but it still wont coast in comfort mode. I'm a massive fan of this feature but not a fan of ECO PRO mode.
Also, I can't seem to find any of the launch control posts on here. Has anyone coded this in?
      11-20-2020, 09:56 PM   #2
VipinLJ
VipinLJ's Avatar
I have coded coasting but my car doesn't coast in comfort. I haven't gotten it to coast in eco pro either but I've driven in eco pro only twice. My brother in law managed to get it to coast in eco pro but he drives like a saint.
And you don't need to code LC in. It's already present in our cars. It'll activate only if you follow the steps correctly (in most cases, it's the TC button that confuses people (me included) - LC will work only if you click it; won't work if you long press it to disable DSC).
2020 BMW 330i xDrive
2018 Audi SQ5 Prestige
2017 Audi A7 Prestige
      11-21-2020, 07:53 AM   #3
rickkap
Drives: 320d XDrive M Sport (G20)
oh.. this is interesting as i could never get LC to show up or work.. so what is the full procedure that you use, if you don't mind sharing?
Not sure if it makes a difference but i have a g20 320d m sport xDrive
      11-21-2020, 10:13 AM   #4
VipinLJ
VipinLJ's Avatar
Ahh. Not sure if the 320d has LC but I'm guessing it should.
1. Engine should be warmed up (engine oil temps should be 165°F at least). For that, you'll have to drive around for a bit before you try engaging LC.
2. Car in sport/sport individual/sport plus mode.
3. Shifter in S.
4. Click TC button once (not long press it). It should show sport traction or dynamic traction or something like that on the idrive and TRACTION in yellow in the live cockpit (not DSC OFF - it won't work if DSC is off)
5. Brake pedal to the floor. Throttle pedal to the floor too (past the downshift button).
6. Launch control flag and notification should pop up in the live cockpit and HUD (if equipped). Don't hold it there for more than a few seconds since the car might start retarding timing and slowing your car down if you don't launch it soon.
rickkap37.50
      11-22-2020, 09:49 AM   #5
rickkap
3. Shifter in S.
Thanks... i'll give it a go and let you know if my car has it
VipinLJ1941.50
      11-24-2020, 05:49 PM   #6
rickkap
My car doesn't have LC
Followed the instruction but i never got the flag on the idrive, but it did move off pretty quick
      11-24-2020, 06:52 PM   #7
VipinLJ
VipinLJ's Avatar
Did you check the owners manual in the iDrive? Search for launch control there. If it's mentioned there, your car should have it. If not, it won't.
      11-28-2020, 08:39 PM   #8
X32G20
Drives: G20
I have a 330i G20, 2020. I checked the owner’s manual, and launch control is explained there. I followed all of these steps, but am having trouble at the last point. I put the brake all the way down, and then I press the accelerator. I can feel the car bearing down, engine fighting against the brakes, and it revs, but no launch control. Maybe I’m not pressing the accelarator hard enough/past the kick down, but for launch control, should we expect the car to feel like it’s engine fighting against the brakes? I got nervous and felt I was putting too much stress on the car
      11-28-2020, 09:33 PM   #9
Merami fan
めらみぽっぷ fan
Merami fan's Avatar
Drives: 2020 330i xDrive
Both pedals all the way down. Takes 2-3 seconds after you floor the accelerator.
Username and profile picture in admiration of the goddess of treble, めらみぽっぷ (Meramipop).
https://www.youtube.com/watch?v=fQYWhQXOeQg
https://open.spotify.com/playlist/1w...1L3y6cmPEyGSoI
      11-28-2020, 09:47 PM   #10
X32G20
Drives: G20
But do you feel your car fighting the brakes right before launch control activates?
      11-28-2020, 09:49 PM   #11
VipinLJ
VipinLJ's Avatar
Yes. The car strains a bit. If it was a dual clutch transmission, it wouldn't (my A4 didn't).
Do you get the flag on your live cockpit? LC gets activated only when you floor the throttle pedal past the kickdown button.
      11-28-2020, 09:51 PM   #12
X32G20
Drives: G20
I think I chickened out once I felt the car straining, can’t remember if I went past kick down. I will try again once I work up the courage haha
      11-28-2020, 11:42 PM   #13
VipinLJ
VipinLJ's Avatar
Ahhhh. I don't blame you. But once you do it, you'll get used to it. The trick is to mash the throttle pedal. Not press it down slowly. Once you're on the brake with all your might, mash the accelerator pedal till RPMs rise to around 2800-2900 and the flag comes on. Don't wait for too long. Release brake pedal and you'll be on your way.
Always make sure you're on an empty road.
      11-29-2020, 03:52 AM   #14
vsterian
Drives: BMW 320xd G20
Does anybody know how it should the LC Flag look on "Live cockpit plus"?
Just as described in an earlier post, I did not see any flag even though the car went pretty fast and the same thing, I don't remember kicking it past the "kick-down" point...
LE: After you push both pedals down bellow the kickdown point, it does show the Launch Control Flag!
      11-29-2020, 09:04 AM   #15
VipinLJ
VipinLJ's Avatar
Flag looks like in the post below
https://g20.bimmerpost.com/forums/sh...6&postcount=64
      11-29-2020, 09:25 AM   #16
vsterian
https://g20.bimmerpost.com/forums/sh...8;postcount=64
Yes, but that's the Live Cockpit Professional. I the Live cockpit plus which looks like the one attached.
Btw, I forgot to mention on my last post, I have a 320xd M Sport with Sport Transmission.I Heard that the ones without the sport transmission does not come with LC and has to be coded.
      11-29-2020, 10:54 AM   #17
VipinLJ
VipinLJ's Avatar
Ah yes. You need the sport transmission to get LC. I believe you can code it in with esys. Not with Bimmercode.
      11-29-2020, 03:10 PM   #18
M3ditate
Drives: ALL of them
[/QUOTE]
I have a 330i G20, 2020. I checked the owner's manual, and launch control is explained there. I followed all of these steps, but am having trouble at the last point. I put the brake all the way down, and then I press the accelerator. I can feel the car bearing down, engine fighting against the brakes, and it revs, but no launch control. Maybe I'm not pressing the accelarator hard enough/past the kick down, but for launch control, should we expect the car to feel like it's engine fighting against the brakes? I got nervous and felt I was putting too much stress on the car
It will be instant, DO NOT wait 2-3 seconds, as this will cause unnecessary wear.
Left foot on the brake, as hard as you can, and then gas pedal PAST the kick-down, if a checked flag doesn't pop up, you did it wrong.
Only requirement for the vehicle being equipped with LC is a sport transmission, which is standard for US on G20.
Also, it can be launched in comfort, doesn't need to be sport. Make sure the shifter is to the left.
      12-01-2020, 05:46 AM   #19
fakca38
Turkey
Drives: bmw g20 2020 3.20
I did this coding on my 2020 bmw g20 vehicle, but it does not work in sailing comfort mode! On / off is also displayed on the screen but it doesn't work! is it correct?
      12-02-2020, 01:25 AM   #20
vsterian
As far as I know, special conditions must be met in prefer to coast on comfort mode and eco mode. My car came with default coasting on both driving modes, but I noticed that since the weather changed ( winter in coming) I see less and less sailing.
Maybe it has something to do with this...
      12-02-2020, 03:00 AM   #21
rickkap
Also, it can be launched in comfort, doesn't need to be sport. Make sure the shifter is to the left.[/QUOTE]
I've check the manual and there is a full description of LC but as X32G20 i don't get the flag.
I tried being very harsh with the accelerator, by that i mean flooring it past the kick down.
Maybe a daft question but how do you know if you have Sport Transmission? i have the sport button, but i'm under the impression that this isn't anything to do with the transmission. Sorry if this is a lame question but it would be nice to clarify it.
      12-02-2020, 03:19 AM   #22
vsterian
The Sport Transmission it's the one that has flappy paddles behind the steering wheel.
rickkap37.50
