Technical Topics Wheels and Tires Post Your Aftermarket Wheel Set Up!
      07-19-2021, 08:11 PM   #221
RigRag93
Drives: BMW M340i
In the development phase, but here the Curva C70s in 19x8.5 F and 19x9.5 R
      07-19-2021, 08:28 PM   #222
PLF69
PLF69's Avatar
3766
Drives: 2023 M3
Offsets ?
Fun/HPDE: 2023 M3 6MT Individual Malachite
Past:2023 M4 CSL, 2022 M4C Vert, 2020 M340i, 2018 M2, 2015 M235i, 2008 135i 550whp
Daily: 2023 X5 45e
Daily/Family: 2021 Atlas Cross Sport 3.6
      07-20-2021, 10:45 AM   #223
RigRag93
Drives: BMW M340i
Originally Posted by PLF69 View Post
Offsets ?
As of right now, these are considered a test fit. Curva is developing a wheel that will be in the proper specs.
19x8.5 +35 (+15mm spacer / +20)
19x9.5 +35 (+5mm spacer / +30)
I feel like with these specific wheels and their profiles, another 5mm on the front and rear would have been good.
Juny2145.00
      07-24-2021, 04:56 PM   #224
Barry9020
Drives: 19 m550i
can anyone tell me if this tire setup would be okay for a m340i xdrive?
20x9 25et 245/40/20F
20x10 33et 275/35/20R
i see people running the same spec rim, just dont know if the tire size will fit the m340i xdrive.
      08-12-2021, 12:16 PM   #225
tosswill
tosswill's Avatar
Drives: 2020 BMW M340i X-Drive
If you go with those profile sidewalls you're increasing overall diameter of all four wheels by 5-6% which seems a lot, and will have the effect of gearing up the car (if I'm not mistaken), which I suppose would put more pressure on the drivetrain long-term.
If I were you, I'd revise the tire sidewalls to 35 front and 30 rear. Still allows a good amount of sidewall on the tires and keeps the difference front-to-back within the scope for X-Drive. Offsets should work well as you have them, I plan to do something similar soon with the following specs (I have X-Drive and Adaptive Suspension which is a little bulkier on the strut):
Front: 20x8.5 et 15 - 245/35/20
Rear: 20x10 et 37 - 285/30/20
I should note, I'm relatively new to all this myself, but have done a lot of research at this point.
      08-18-2021, 10:42 AM   #226
Barry9020
Drives: 19 m550i
awesome thank you bud!
      08-29-2021, 10:02 AM   #227
Mr.G20 M340
Mr.G20 M340's Avatar
Drives: 2020 Portimao Blue M340-x
New wheels, new diffuser, new bumper. Need to add Sideskirts and front lip and thinking of powder coating wheels bronze.
Instagram: Bmw_Captivate
2020 Portimao Blue M340 X Drive and adaptive suspension.
Mods: custom exhaust, VRSF Catted DP, Injen intake and Chargepipe.
Appreciate 7
Rocket455484.00
chenry2357.50
fuxxo136.50
Whack0119.00
      08-29-2021, 06:27 PM   #228
ssgm1x
ssgm1x's Avatar
Drives: 2020 M340i & 2018 M3
TSW 19" Wheels Satin Black on DWS06 Plus tires
Sorry for the dirty tires.....
2020 BMW M340ix Dravit Grey
2018 BMW M3 Alpine White
      09-01-2021, 12:35 PM   #229
Rocket455
Grumpysaurus Rex
Rocket455's Avatar
Drives: 2022 M550i
1972 Firechicken  [0.00]
1969 Toronado  [0.00]
1970 Camaro  [0.00]
Wow. I'm loving the aggressive diffuser and front bumper! Not sure if you even need a lip on the front any more! How's the fitment of both the diffuser and front bumper?
      09-10-2021, 11:34 PM   #230
JetPump
Drives: BMW M340i RWD
Powder coating aluminum above 300 degrees F will revert the temper in the material, making it soft. It’s a temperature and time function where 300F is not going to change it much but a couple hours at 450F will make a permanent reduction in strength.
      09-11-2021, 10:51 PM   #231
dezau
Drives: C63 S
Took a few wheel spec as reference and took a gamble on these FlowOne wheels on sale on TireRack, I think it turned out pretty good.
Tires are some clerance 265/35-18 RE71R TireRack found in storage. Wheels and tire are both square setup.
Car has since been dropped on Dinan Springs, no rubs or issues so far.
The front ended up needed a 5MM spacer cause it wouldn't clear the strut.
PLF693766.00
      09-12-2021, 04:00 AM   #232
PLF69
PLF69's Avatar
3766
Drives: 2023 M3
Yesss ! Thank you for pushing things further !
What are the specs of the wheels?
Daily: 2023 X5 45e
      09-12-2021, 06:49 AM   #233
dezau
Drives: C63 S
Sorry I thought I edited that in.
18x9 +35 square, 5mm spacer in the front.
      09-12-2021, 07:13 AM   #234
PLF69
PLF69's Avatar
3766
Drives: 2023 M3
No problem, you actually did it in the other thread.
So much more option in 18inch. I may look into swapping to M3 brakes if I find a cheap kit to be able to go down to 18inch
I am restrained to 19inch with the track package unless Apex releases some high clearence 18inch wheels wich could be very possible.
dezau Do you think 265/40-18 would fit well ?
Daily: 2023 X5 45e
      09-12-2021, 11:21 AM   #235
dezau
Drives: C63 S
For the front, mayyybe. Might be a little tall.
For the rears, I'm 90% sure it wouldn't be a problem. It'd help with 2nd gear top speed a little cuz it tops out at 51.
      09-12-2021, 11:24 AM   #236
PLF69
PLF69's Avatar
3766
Drives: 2023 M3
Have to agree the ratio difference between 2nd and 3rd gear can be a bit annoying in some situations..
Daily: 2023 X5 45e
      09-13-2021, 04:09 PM   #237
dezau
Drives: C63 S
No rubbing...
tarrant64116.00
      09-14-2021, 07:15 AM   #238
andrewasf77
Drives: 2019 BMW 330i sDrive
Brand new to the forum and brand new to the BMW family. I have a 2019 330i sDrive. I want to switch to a 20" bronze wheel/tire combo. looking to keep the stock feel and drive, will also add a slightly lowered stance in the near future. Any recommendations? Thank you!
      09-14-2021, 10:47 AM   #239
jeegunkim
jeegunkim's Avatar
328
Drives: 2020 330i xDrive, 2023 M3CX
2020 MG 330i xDrive M Sport
2023 AR M3 Competition M xDrive
      09-18-2021, 09:48 PM   #240
CharlesC
Drives: G20 M340
BBS CH-R 19x8.5 with factory runflats until they need replacing (then trying for a 255/35). Added a 12mm spacer front and rear and sits really nicely. Just need a combo of some coilovers or lowering springs and some meatier tires.
BMW M340_01
by Charles Clay, on Flickr
BMW M340_07
BMW M340_05
BMW M340_02
      09-22-2021, 01:24 PM   #241
Collindabin
Drives: 2013 BMW 340i
If you're in Canada you got to check out www.wheelsnearme.ca - just got some wheels and tires from there and it came in 2 days.
      09-22-2021, 08:54 PM   #242
johnnyg238
Drive it like you stole it
2020 BMW M340i  [0.00]
BBS 20inch CI R wheels
New to me.
